12-26-2009, 12:09 AM   #1
K20 , Sigma 24-135, and the menu
This is fairly weird, so I'm hoping someone else has run into this issue and found the fix/bypass/workaround.
I've noticed that the menu for settings on my K20D was acting like the four way button was screwed up; limited duration display of the menus (0-2 sec) was the norm with an occasional tantalizing almost get you to your item to change before the screen blanked out. I have tried different batteries, upgraded the firmware to 1.03, and it was still acting weird.
Then I took my Sigma 24-135 off the body. Hmmmmmmm. Now the settings displays stay on screen. Tried three other lenses. No problems . So I'm guessing it's something in the Sigma mount that's causing a problem . The camera shoots nice pictures and the play button works as it should.
I'm assuming it's a dirt issue first, then maybe a short. The lens clicks home on mounting and the issue does not occur on my K10D with this lens. Am I on the right track and where should I start the cleaning op , if so ?
12-26-2009, 05:17 AM   #2
when i had my sigma 24-135, it would cause my former *ist DL's menu to blank out.
i think this is a known issue with the sigma at least with the older pentax dslrs
no amount of cleaning the contacts helped.
HTH
12-26-2009, 06:39 AM   #3
dadipentak's Avatar
One of the reviews here does mention an incompatibility issue.
button, camera, dslr, issue, lens, menu, photography, screen, settings, sigma
Finally got a chance to use the K20 & DA* 50-135 =) PICTURE heavy! DuckysDoll Post Your Photos! 23 01-21-2009 10:13 PM
For Sale - Sold: FS: FA35, FA50, Sigma 24-135, DA50-200, Sigma 500 DG Super Supa Lao Sold Items 28 03-13-2008 07:30 AM
For Sale - Sold: FS: Sigma 24-135 F2.8-4.5, Sigma 28-105 F4-5.6, TOU/FIVESTAR MC 70-200 F4 m ramzey Sold Items 2 12-31-2007 03:03 AM
All times are GMT -7. The time now is 06:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
