12-26-2009, 12:23 PM   #1
K10d - Menu Problems...
I have owned my K10d since Feb '06 and have mostly been happy with it... Lately i have been having problems navigating the various menus with them "blinking" off prematurely. At first it was random and infrequent, now I cannot access any menu long enough to make any changes. It doesn't matter if its the main menu, or the Fn menu to do something simple like change WB. The moment you turn on a menu they immediately close again. The camera shoots and fires fine (except WB is way off, despite being set for auto WB currently, has a very cold blue hue to i with certain lenses but works fine with others). Shutter fires fine, aperture and shutters speeds adjust ok. About every 10th time I turn it on the menu will work for 5 seconds or so and was able to get in and do a reset but that has had no effect on the problem at all.
Anyone see anything like this? At this point I doubt there is any reason to fix it as opposed to a new body.....
12-26-2009, 12:26 PM   #2
Canada_Rockies's Avatar
If you are considering upgrading to the k20, the batteries are the same. I would swap in a new battery, fully charged, and see what happens, or if you already have a second battery, use that. If you are using the grip, remove it and test. I have two year old batteries, and they are still working, but yours are nearly four years old. There comes a point when you must spring for new batteries. They have a life expectancy, just like the battery in your vehicle.
12-26-2009, 12:28 PM   #3
Yeah I have two new batteries for it and tried both and then tried one of the older ones after a full charge and it still does the same thing.. I guess I shouldn't complain, its seen a lot of use and travel and the last time I figured it out I was around 150,000 images shot....
12-26-2009, 12:36 PM   #4
QuoteOriginally posted by mrchris Quote
With that many images taken, I think you got more than the mileage expected out of your camera. Go for whichever new one turns your crank - or maybe pick up a good used one in the marketplace.
12-26-2009, 01:12 PM   #5
kkoether's Avatar
Sounds like a stick push button somewhere. I have a battery grip on my K200D and if I inadvertly hit the shutter button on the grip when it's turned on I get what sounds like the same thing. Just something you might want to look at.
12-26-2009, 02:52 PM   #6
noblepa's Avatar
EXIF contains shutter count
You can find out exactly how many times your shutter has been tripped. Just take a picture, load it onto your PC and use Opanda, Photo ME or Exiftools to display the exif data. The shutter count is included for every shot.
I agree that, at 150k shots, you've probably gotten your money's worth. That's a lot of shots.
camera, dslr, fires, k10d, k10d menu, menu, photography, wb
K10D Service Menu and AF Adjust! nosnoop Pentax DSLR Discussion 55 03-29-2019 10:23 AM
K10D Crashing when changing options in menu? jmdeegan Pentax DSLR Discussion 20 07-14-2008 08:34 AM
K10d-debug menu-IR possible? Bokeh Pentax DSLR Discussion 6 05-17-2008 05:54 PM
Menu Screen on K10D RussellW Pentax DSLR Discussion 12 02-04-2008 07:12 PM
K10D Menu Typos Faither Pentax DSLR Discussion 13 12-02-2006 10:28 PM
All times are GMT -7. The time now is 04:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
