01-02-2010, 10:15 AM   #31
Lowell Goudge's Avatar
OK so here is the results
compare *istD, K10D, K10D with *istD focusing screen, and K7D all with the same 50mm F1.4
In reality, the *istD is the champ. Followed by the K10/K20 with an *istD screen.
01-02-2010, 11:22 AM   #32
blende8's Avatar
Thanks for the test!
The K7 is better than K10/K20, but still not good enough.
The screen/metering sensor system is not very well calibrated, it seems.
01-02-2010, 11:28 AM   #33
SteveM's Avatar
I'm finding this thread interesting.... I have had the K10d, and have the k20d and K-7. As soon as I received my K-7, I noticed a great improvement in the quality of shots with manual glass.
01-02-2010, 01:55 PM   #34
QuoteOriginally posted by smc Quote
I would say from my test, and I still need to test about 15 lenses, that above F5.6 there is a 1 stop improvement on the K7 VS K10,
01-03-2010, 03:01 AM   #35
axl
Lowell, have you had the chance to test K10/20 with other screens? Like Katzeye or K3?
BR
Peter
01-03-2010, 07:56 AM   #36
QuoteOriginally posted by axl Quote
BR
Peter
Not yet
I have a jinfinance diagonal split image in my K10D and need to check this. Spot metering is no good, but I can do average metering and see what happens.
In principle I sould recheck the K10 with all my lenses to see what happens.
Note every lens seems to be a little different and at one point I had plotted all my lenses out with the K10 and *istD.
I need to re-do the K10 with split image and do more for the K7 but as you can imagine, each lens takes abot 12 shots to characterize. THis takes about 1/2 hour per lens per body
06-18-2013, 02:39 PM - 1 Like   #37
I have been shooting with a Pentax KX K200D, K30 and K7 to date I am still using all. and have many legacy lenses the K7 is awesome with the older lenses I don't shoot much in low light but when I have, setting up with Manual setting on the K7 with proper shutter speed and aperture I can shoot with Low ISO 100 to 400 with Great Images.
06-19-2013, 01:49 PM   #38
This is an incomplete reply as I use the K200D and the Samsung GX20 mostly with manual lenses (these manual lenses are mostly SMCP-M; exception is the M42 screwmount CZJ Flektogon 35/2.4). With an LL-60 screen installed, GX20 gives broadly accurate exposure with manual lenses with some inaccuracy towards aperture extremes. With SMCP-DA lenses, +0.7 exposure compensation is needed to get a reasonably accurate exposure and multi-segment metering works best. In the K200D (not applicable in the present thread), most SMCP-M lenses meter quite accurately though occasionally I have found inconsistent exposure with these lenses, especially at extreme apertures (more so than with the LL-60 screen on the GX20). This is correctable by turning the aperture ring to openi up or close down a few clickstops. With SMCP-DA lenses the K200D underexposes in bright light, reportedly to protect highlights. Metering for both cameras was done with the green button and always in M mode.
2. Though it is convenient to use the SMCP-DA lenses even in M mode, my own preference is to use SMCP-M lenses, even though it means focussing manually and using the green button to stop down and get the shutter speed. The Flektogon requires the additional step of opening up the aperture to focus (so as to see clearly), closing it down to the requisite aperture stop and pressing the green button to get the shutter speed. . The main obstacle is the small APS-C viewfinder and its lack of brightness: it is difficult to see properly, particularly for people nearing their sixties.
Chhayanat
12-26-2013, 12:38 PM   #39
Pentacx k10 - lens compatibility
My husband gave me a F80 200 lens for Christmas... but it seems that is not compatible with my k10 camera... It does shot... any ideas?
12-27-2013, 05:30 AM   #40
sterretje's Avatar
@ amontecinos
You need to give a better description of the problems you're experiencing. And maybe it's better to start a new thread.
camera, dslr, iso, k10, k20, k7, lenses, photography
k10 or k20 houstonmacgregor Pentax DSLR Discussion 13 03-06-2010 10:37 AM
used K10 VS used K20 MacKay Pentax DSLR Discussion 7 02-17-2010 11:23 PM
for k10 and k20 owners Davidex Pentax DSLR Discussion 10 09-23-2009 11:34 AM
K10 vs K20 - go thePiRaTE!! Pentax DSLR Discussion 11 03-09-2008 03:28 PM
P67 lenses on K10/K20 Don Boyd Pentax SLR Lens Discussion 5 02-15-2008 12:22 AM
All times are GMT -7. The time now is 06:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
