Originally posted by Marc Sabatella Yes, but how much of that difference is just because the K-x does more NR in-camera, even for RAW? That is to say, you should be able to improve on the K-7 results by doing the NR yourself, even if just a batch preset.
There are two things.
1.Do kx files have significantly less details than k7?? (not because of 14 to 12 mp thing but because of noise reduction).
2. If answer to 1 is no , then if you can reduce noise by post processing on k7 files, you could also apply same to kx files too.
What you said is valid only if you can not process kx files but can process k7 files by NR program.
To answer this, someone should take samples from raws and try to process them by some noise reduction program and see whose results are better.
My guess it will be kx who will come out on top because of better files to start with.
I have been reading that all NR in raw argument but I think k7 also applies NR to raw. (correct me if i am wrong on this one).
PS: I must admit though, i would rarely shoot anything above iso400. And high iso thing played zero role in my buying kx. (I was only bothered about mp and liveview, both were issue on k100d).
