06-17-2007, 07:52 PM   #1
Flash Fried K10d? how do i know i'm safe?
i have an old vivitar 2000 flash. how can i tell if it is safe to use with my k10d?
06-26-2007, 06:25 PM   #2
Not familiar with Vivitar 2000 flash. Think it was/is very inexpensive. There are a couple of issues to check when using a non Pentax flash.
1. Flash dedication. All "hotshoe" electronic flashes will have a single contact in the center of the camera hotshoe. If there are no other visible contacts (they will be smaller) the flash is non dedicated. If there are extra small contacts the flash is dedicated. If using dedicated flash on dedicated camera (all dslr) they must "match". Can't put a Nikon dedicated flash on dedicated Pentax camera. Nikon didn't check with Pentax when they designed their flash system. Nor did Canon, Olympus, or Sony/Konica/Minolta. You can short out flash, camera, or both mixing dedicated systems.
If flash is dedicated to Pentax you can use at least some of the flash functions as long as flash passes #2 below. TTL won't work unless you have D,DS,DS2 bodies. Auto eye on front of flash will work.
2. Even if flash isn't dedicated you have to check the trigger voltage. Especially older flashes. High trigger voltage can fry a digital camera. This wasn't a problem in film camera days. To measure trigger voltage take a digital multimeter (or older vom) set to DC voltage and turn on the flash. Do not have flash on camera. Put + tip on the center contact of the electronic flash. The minus tip goes to the metal rails inside the left or right edge of the flash foot. Look close you will see them. Most digital manufacturers recommend 24v or less. DSLRs probably can handle a little more, but is it worth the risk? New non dedicated flashes are cheap. If you don't know how to check the flash or don't own a meter ask a friend or go to a real camera shop. They will be able to check it for you.
Hope this helps. Flash can be a little complicated. So many systems, so many changes. A good flash is very important to have.
thanks
barondla
06-26-2007, 06:33 PM   #3
jfdavis58's Avatar
Sizzle....
QuoteOriginally posted by sketchin13 Quote
Try it?!?!?!
Play it safe; use a hotshoe condom.
The phrase you're looking for is "Flash trigger voltage"; and google is your friend!
A 'good' answer is on this page.
The short answer is "NO".
06-27-2007, 02:28 AM   #4
ABSOLUTELY NOT. Stop, do not pass go, do not collect $200.
This flash has a very high trigger voltage. 3 tests vary from 54.4v to 202v You will most probably fry your camera.
According to Pentax USA, you are safe with a trigger voltage of less than 25v. Personally, I wouldn't mount anything with more than 7-9v.
Check this list out. Should be a big help when looking for a 3rd party flash.
Photo Strobe Trigger Voltages
camera, dslr, flash, k10d, photography
is it safe to use National PE-247S flash on K20D hoyquest Pentax DSLR Discussion 1 01-14-2010 02:43 AM
is this old flash safe for K200D? trna Troubleshooting and Beginner Help 9 09-09-2009 10:41 PM
Safe to use an old Vivitar flash through PC cord/adapter? indytax Flashes, Lighting, and Studio 2 03-27-2009 02:04 PM
Offered a free old flash - but is it safe? tlavoie Flashes, Lighting, and Studio 6 11-25-2008 11:12 PM
10-D and flash Safe Sync question jim bostelle Pentax DSLR Discussion 6 04-14-2007 07:18 PM
All times are GMT -7. The time now is 12:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
