So, I've read a few posts on how to adjust the focus on the K7 / K20/etc. and all seemed to involve a printed chart graduated in cm that one had to set at a 45 degree angle, blah, blah.
I used that method but decided to try another, maybe easier method and see if it gave the same results. Using Scrabble tiles, I used the letters A thru G with A closest and G furthest away. D is in the middle and is the focus point.
The photos below are with the pentax 55-300. 1st taken at 135mm and second at 300mm. You can see that the lens goes from slight backfocus at 135 (compare B & F) to slight front focus at 300 ( compare C & E). So, I'm not going to adjust.
This is the same result I got using the chart.
