12-29-2009, 12:37 PM   #1
esman7's Avatar
Q regarding shutter button on K200D
Hi,
I've used a Pentax K200D for almost a year now and I absolutely love it.
The one thing that drives me nuts is when I'm autofocusing on someone/thing and I have the shutter button pressed halfway down to focus, the hexagon symbol flashes and for a second or two I repeatedly press the shutter button down all the way and still no shutter actuation (usually in lower light situations, but I can see what I want is in focus - the lens is done searching). The lens will then again start searching and then re-adjust will be finally be ready for a photo.
When I use other cameras, say a Canon 7D, as soon as you press the shutter all the way down, a picture is taken (in autofocus mode) even if it hasnít had time to focus yet.
My issue is that I was the priority to take the picture right away. I wouldnít be pressing the shutter button down all the way if I wasnít ready for the picture, now would I?
Iím curious to know if thereís any way around this other than shooting in manual focus, which gives immediate feedback.
Thank you in advance.
Also, does the K-7 or K20D respond like the Canon pro models do? I.e. shutter feedback is immediate, regardless of focus?
12-29-2009, 04:42 PM   #2
I see the same issue with my k200D. Usually in indoor, low-light locations with a nearby subject. Lens choice doesn't seem to matter. I usually have to alter the shot slightly to get the AF to engage, and then re-compose back to my original shot. I hope someone else has a better answer.
12-29-2009, 04:48 PM   #3
esman7's Avatar
Ahh, exactly part of the issue!
Somebody... anybody?
(enter Marc Sabatella with the answer)
12-29-2009, 04:49 PM   #4
If you use AF-C, the shutter will work when you press it. Just make sure your focus is right before pushing the button all the way.
12-29-2009, 05:00 PM   #5
esman7's Avatar
QuoteOriginally posted by flyer Quote
Thanks Yves, is a complete override possible? I do find myself using AF.S quite often.
12-29-2009, 05:37 PM   #6
Fogel70's Avatar
If you configure the OK-button to deactivate AF, the camera will be in MF mode as long as you press OK-button.
12-29-2009, 10:23 PM   #7
AF of the K200D sucks. I've missed many shots of my daughter due to it refusing to lock focus. Even in moderately lit situations if the object of focus is low in contrast it sometimes refuses to lock focus. My new K-X is a big improvement in that department over the K200D.
12-29-2009, 10:52 PM   #8
JohnBee's Avatar
QuoteOriginally posted by Conan Quote
The K20D's are the same.
It's a pain in the ass, and my work around has been to half press again and again to reset the AF system. However... the solution I found was to get a katzeye and be done with it. The only thing the split prism doesn't help with is focus trap to which the AF confirm seems to work much better on moving subjects that static ones.
12-30-2009, 04:53 AM   #9
I've had this happen with my K200D as well, also generally in low light situations. It is certainly annoying, but it does not happen all that often in reality. My 2 main gripes with my K200D are the AF system and the noise above say 800 iso. I know these 2 issues would be cured by the K-x, but I am having a very hard time spending the money on a K-x when my K200 is such a darn good camera otherwise, with certain features that the K-x doesn't have, and without being convinced that the K-x can match the actual picture quality of the K200 at lower iso. Now, if the K-7 could drop to about $700 or less, then I'd be all over that (pipe dream it seems for the time being).
12-30-2009, 12:00 PM   #10
esman7's Avatar
QuoteOriginally posted by jeffrey r Quote
My thoughts exactly... a 3.0" LCD (920k dots) would be nice too...
12-30-2009, 12:01 PM   #11
esman7's Avatar
..oh and as Yves said, AF-C is definitely the best way around this, otherwise it's true... you have to reset the autofocus over and over by pressing halfway, releasing, pressing halfway... and it goes on.
but I love the k200d too much.
12-31-2009, 10:51 AM   #12
Marc Sabatella's Avatar
QuoteOriginally posted by Fogel70 Quote
That's what I do all the time. Half press first to ask the camera to focus, put my thumb on OK, fine tune manually if necessary, then shoot away as much as I like with no further re-focusing. This is the same basic technique I'd expect to use with any camera.
12-31-2009, 02:27 PM   #13
esman7's Avatar
Is this feature available on the K200D or just on K20D and K-7?
12-31-2009, 02:58 PM   #14
I use it on my K200D, and it was also on the K100D and *istDS before that. On cameras with an AF button, that's the button you can customize for this purpose; otherwise, it's usually the OK button. Not sure about K-m or K-x, but imagine they have a button that can be customized to do this too.
12-31-2009, 03:13 PM   #15
Fogel70's Avatar
On K-m/K-x it is the AF/AE-L button you can use for this.
But it is not usable with the DAL kit lenses that are missing quick-shift focus.
button, camera, canon, dslr, feedback, focus, k200d, lens, photography, picture, press, shutter, shutter button
Unresponsive shutter button naomirose Pentax DSLR Discussion 9 05-13-2014 08:45 AM
K1000 shutter button not working?! jzietman Pentax Film SLR Discussion 2 11-01-2010 09:41 PM
Faulty shutter-release button? Mann Troubleshooting and Beginner Help 6 05-30-2009 09:54 AM
ME Super shutter button sticking? oinkely Pentax Film SLR Discussion 3 03-01-2009 01:51 PM
Shutter button - where to find one? Duh_Vinci Pentax Camera and Field Accessories 9 08-05-2007 07:22 PM
All times are GMT -7. The time now is 06:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
