12-31-2009, 10:21 AM   #1
DBZFYAM's Avatar
K-7 frame per second only 4 instead of 5.2?
I've received my K-7 a few days ago and tried to shoot a 5 frame HDR, but the camera stops after 4 shots and then shoots 1 frame per second. Does anyone know why I can't get 5 frames per second?
It does shoot 5 fps when set on JPG, but is only capable of 4 fps when set on DNG.
Settings/equipment:
Write DNG only (also tried PEF)
SanDisk Extreme III 30MB/s 4GB and 16GB card
Manual focus
f2.8
No liveview
Thanks in advance,
Stefan
12-31-2009, 10:26 AM   #2
Disable Distortion Correction and Lateral Chromatic Aberration Adjustment under Lens Correction in page 1 of the Record menu...
12-31-2009, 10:28 AM   #3
gnaztee's Avatar
Well, an HDR is made of images from a range of exposures...the lightest images need slower shutter speeds, so naturally the shutter speed will slow down as you get toward the last one or two shots of an in-camera HDR.
12-31-2009, 10:44 AM   #4
DBZFYAM's Avatar
Thanks for the quick replies! It was indeed caused by the lens correction settings. Didn't know those have such an impact on performance. Thanks again!
camera, dng, dslr, fps, frame, k-7, photography
Contest Poll Contest #41 Voting (Frame Within a Frame) Damn Brit Monthly Photo Contests 31 02-19-2010 05:49 AM
Expired Theme Theme: Contest #41, January, 2010 (Frame within a Frame) Adam Monthly Photo Contests 11 01-21-2010 12:33 AM
Jan 2010 - Frame within a Frame MattBrennan Monthly Photo Contests 0 01-17-2010 06:30 PM
Contest #29, January, 2009 (Frame within a Frame) Joshua Hakin Monthly Photo Contests 0 01-07-2009 09:39 AM
All times are GMT -7. The time now is 08:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
