Originally posted by WillCarney I got the same double image. The main Moon image was over exposed and centered while it gave a second image underexposed like a reflection. I got about six or seven of these till I went to manual shutter and bracketed. If it was a reflection then it should have been in the manual shutter shots as well. That did not happen.
Coincidence. There is no possible way the image could be affected by whether exposure was setting automatically or manually - assuming you used the same exposure, you'd get the same image. If one had a reflection and the other didn't, that would be an accident of a slight change in the shooting angle (even just the movement of the moon might trigger that). While a filter is almost guaranteed to cause these reflections, it's possible to get them without a filter, particualr on a lens without "digital" coatings.
