Originally posted by mppuser Ok so there seems to be some difference of views on this but there are two questions....
1 - Max voltage allowed at the Hotshoe
2 - Max voltage allowed at the PC contact
Hello DG,
I had much the same questions before connecting up my P&K ringflash and bugged Pentax UK quite a lot for answers. I ended up getting two; 20V over the phone from the engineer and 25V in a helpdesk mail.
I the end I ended up using the ringflash on the PC sync and it works just fine, the camera doesn't go pop.
ben_edict helped me establish, through measurement, that the pc-terminal's central contact is not directly wired to the bigger, central contact of the camera hot shoe, and we assumed that it is a traditional mechanical (or electro-mechanical) switch and the pc-terminal is not connected to the camera's internal electronics.
