02-04-2010, 06:45 PM   #31
Pentaxor's Avatar
QuoteOriginally posted by grey goat Quote
I just yesterday got a new K-7, and I'm in the beginning stages of figuring things out.
But one thing I wondered about was the firmware update. Reading this thread made me, well, a little wary of the latest update, US or Japanese version.
I have a really goofy question, though: how can one determine which firmware version is installed in the camera? I searched here, and looked at the Pentax site, and have hunted in the manual. I might be missing something somewhere.
If someone could point me in the right direction, I'd be grateful.
turn on camera while pressing INFO button.
02-04-2010, 06:51 PM   #32
ivoire's Avatar
Just hold the menu button down while turning on the camera to display the firmware version. My problem was not firmware related.
02-04-2010, 07:16 PM   #33
Pentaxor's Avatar
QuoteOriginally posted by ivoire Quote
oh, was it the menu button?
I hate it when both buttons are located in the same area.
02-04-2010, 08:14 PM   #34
jgredline's Avatar
Oh and I should mention that the last, latest update worked pretty good.
02-04-2010, 08:38 PM   #35
grey goat's Avatar
Thanks, ivoire. (And Pentaxtor, too!)
It's good to hear you got your K-7 back, ivoire.
I downloaded the latest firmware update--well, the US version, 1.02.14--and got it installed, no problem. I had 2/3 battery life remaining, but the instructions scared me into putting my fresh battery in there. And then the update took all of 90 seconds.
So, has anyone figured out the difference between the 1.02.14 and 1.02.16? Am I missing something important now? I know I can simply download the version from Japan, but I guess I'm figuring that it's been out since October 22 in Japan, and it hasn't been posted at the US site, so I'm not sure I feel the need to update right away again.
Anyway, thanks for your help, folks!
02-04-2010, 08:54 PM   #36
Pentaxor's Avatar
some people say it is a fix for the SR bug that causes unsharp images when SR is activated at high shutter speed.
02-04-2010, 09:16 PM   #37
grey goat's Avatar
QuoteOriginally posted by Pentaxor Quote
Well, in that case, I suppose it is worth downloading. But maybe not tonight.
Besides, maybe firmware version 1.03.xx will be released tomorrow. . . .
02-05-2010, 11:52 AM   #38
Is it a rumour, wishful thinking or you have some pretty reliable info?..
02-05-2010, 12:32 PM   #39
grey goat's Avatar
QuoteOriginally posted by Denethor Quote
Just a bit of wishful thinking, that's all.
There are things I suppose I wish would get added in firmware, but right now I'm too busy figuring out what the K-7 can actually do.
I don't know enough about Pentax's firmware release history to have any real idea how often new firmware shows up, but if the last release was in late October '09 . . . well, it depends on whether Pentax figures out there's something worth adjusting, I guess.
02-05-2010, 01:48 PM   #40
This is interesting information. I just got a K-7 as an upgrade to my K100D and in comparison to the K100D I have been somewhat underwhelmed with the IQ of images out of the K-7 in low light. I believe my K100D is noticably better at seemingly the same settings with the same lenses in low light.
I can't figure out if it is focusing issue or noise issue, but I'm to the point where I am comparing pictures of the same subject, with the same lens on each camera and trying to get a better image out of the K-7. So far I've failed. White balance is definitely better on the K-7, but focus and noise are worse. Is this to be expected? Any suggestions?
JPEG format
FA50mm 1.4 lens
testing in ISO 800 to 1600
testing in both auto WB and also Tungsten setting
Thanks in advance,
Mike
02-05-2010, 01:51 PM   #41
netuser's Avatar
QuoteOriginally posted by sillyzippy Quote
JPEG format
FA50mm 1.4 lens
Thanks in advance,
Mike
Don't forget k-7 gets at the best using/developing with raw instead of jpeg.
Also, understand since it has more mpixels it will have more noise (that of course on PP you can deal with)
02-05-2010, 01:57 PM   #42
Should I try dialing down the mpixels to 6 or 10 to be similar to K100D?
02-05-2010, 02:12 PM   #43
netuser's Avatar
If you are going to print the same size as you did with the k100d it will be more or less the same.
Instead of dialing down you should perfect your PP, if it's the case.
I discover that jpeg engine of k7 is terrible BUT raw developing gives the best IQ against what you want to compare
Give it a try...
camera, dslr, firmware, k7, k7 firmware, photography
Tamron 17-50mm a worthy "downgrade" (from Pentax 16-50mm)??? Ubuntu_user Pentax SLR Lens Discussion 53 11-07-2010 06:23 PM
K200D to K-x: upgrade, downgrade, or "sidegrade"? ChooseAName Pentax DSLR Discussion 19 07-19-2010 09:36 AM
Did I just downgrade to K100D Super, or actually upgrade? pentaman Pentax DSLR Discussion 28 12-14-2009 10:14 PM
Considering a body downgrade--have I lost my mind? heatherslightbox Pentax DSLR Discussion 15 06-02-2009 07:12 AM
K200d owner Downgrade??? shiestmiester Pentax DSLR Discussion 14 02-25-2009 02:22 PM
All times are GMT -7. The time now is 08:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
