01-04-2010, 12:25 PM   #1
Giottos LCD protector for KX?
Hi,
Giottos doesn't make a screen protector specifically for the KX but the SP8270 is almost the right size. The KX LCD is 60x49mm. The SP8270 is 60.8x48mm.
Has anyone with a KX used this protector to comment if the size difference is a problem? Or if the border of the SP8270 reduces the viewable area of the KX LCD?
Or more generally if there are any other high quality screen protectors (not vinyl adhesive type) that work with the KX?
thanks,
Fred
01-06-2010, 09:03 AM   #2
I am interested on that as well..
I do have the Giotto for the K10D, and the Kx needs one too!
Anyone with the correct part number?
01-06-2010, 09:54 AM   #3
dcmsox2004's Avatar
hi... there's acmaxx 2.7inch available... ebay
01-07-2010, 01:13 PM   #4
I also uses the ACmaxx ( for my K7 that is), perfect fit.
They are sold on ebay
ACMAXX 2.7" HARD LCD ARMOR PROTECTOR Pentax - K-X Kx DA - eBay (item 260524983155 end time Jan-15-10 23:33:11 PST)
01-08-2010, 11:11 AM   #5
ACMAXX display
QuoteOriginally posted by Sakura Quote
Sakura,
Thanks for the link. Does the ACMAXX in any way impact viewability of the LCD on your K7 (good or bad)? Glare increased or decreased? Viewing angle?
thanks,
Fred
01-10-2010, 08:17 AM   #6
Not as far as i could notice, it is very clear and the glare is not much more than the than the screen itself.
The protectors has a small edge around the screen what it uses to sticks at the LCD screen, so if you ever have to remove (or replace) the screens it is very easy to take them off again. It isn't glued to the entire screen but just around the edges.
camera, dslr, giottos, kx, lcd, photography, protector, screen, size
LCD protector Warren s Pentax Camera and Field Accessories 13 03-29-2010 04:46 PM
Giottos glass screen protector StevenVH Pentax Camera and Field Accessories 2 12-07-2009 09:16 AM
LCD protector kibipod Pentax DSLR Discussion 6 12-27-2008 01:27 PM
LCD PROTECTOR ? Found it !!!! Tom Pentax Camera and Field Accessories 5 10-03-2007 08:18 PM
LCD Protector for K10D MShawn63 Pentax DSLR Discussion 12 06-20-2007 12:34 PM
All times are GMT -7. The time now is 06:29 PM. | See also: NikonForums.com, part of our network of photo forums!
