Originally posted by 440roadrunner I should have mentioned I had a small 35-135mm zoom at 135, I think I was down to 1/15--1/30 or so, so I would have thought that would have instigated shake
Am I correct in assuming that I ONLY will see it in the shot, and not anything in the viewfinder? (Used to my Canon)
I've got a Tamron 60B 300mm 2.8. Maybe I'll go out tonight at dusk and play around with that thing.
Note that with In camera (i.e. sensor compensated) SR, you don't see it in the view finder.
your canon had in the lens shake reduction which shows a stabilized image in the view finder because it is after the shake reduction process
In camera SR the view finder is via the mirror, which is in front of the sensor and any image stability with SR.
On the K7 with optical preview you can see it on the LCD
