Originally posted by photolady Also, can the dpi be changed so when shooting jpeg, it isn't set a 72dpi?
First the question above: I think yoo need to go into your camera menu and change the Quality Level setting [my DS has a Raw setting and 3 Jpeg settings].
As for using the manual lens [this works for my DS]: You need to go into the Custom Settings menu (not the Record menu) and set the "Using the Aperature Ring" to 2 (permitted), set the mode to Av, press the AE-Lock button (this will activate the aperature and allow the camera to set the shutter speed for the aperature you selected. The F value will not show on your screen.
Enjoy the new lens.
Tim
PS: If the AE-Lock doesn't do the trick, you might try pressing the shutter half-way to activate the aperature/metering system.
