06-22-2007, 08:29 PM   #16
Moderator Emeritus
Leadbelly, send me an email at ptz1961@hotmail.com
06-22-2007, 11:25 PM   #17
PM and email sent sir!
06-23-2007, 08:03 PM   #18
vagrant10's Avatar
QuoteOriginally posted by Peter Zack Quote
As for the shutter speed rule of thumb, ie: shoot at the lens's focal length (with a 200mm lens shoot @ 1/250th, 50mm @ 1/60th etc.) and the minimum was pretty much 1/60th with any lens to be safe. The SR seems to give me good results 2-3 speeds lower and can sometimes get a good shot 4 times lower (but rare).
sorry to jack the thread, but thanks for that bit of info! I had been trying to keep my speeds above 1/125th for all my shots so that rule of thumb will be helpful as I learn the ropes on dslr's.
06-24-2007, 05:37 PM   #19
I'm slowly getting the hang of my K100D, but when I adjust the shutter speed, I get confused... the values in the viewfinder are in single digits, and sometimes I get "lost" after much adjusting... what does it mean when the shutter value is 0.3? I'm learning to use Tv mode first before moving on to the others...
06-24-2007, 07:20 PM   #20
Moderator Emeritus
QuoteOriginally posted by leadbelly Quote
Do you mean 0.3" ? That " indicates seconds so it's 0.3 of a second, (1/3) not to be confused with 1/30th of a second.
Going from the camera the shutter speeds start at the longest first, 30" meaning 30 seconds:
30"25"20"15" 13"10"8" 6" 5" 4"3" 2.5" 2" 1.6" 1.3" 1" 0.8" 0.6" 0.5" 0.4" 0.3" then the speeds above 1 second 4 meaning 1/4th (slow) or 640 meaning 1/640th (fast)
4,5,6,8,10,13,15,20,25,30,40,50,60,80,100,125,160,200,250,320,400,500,640,
800,1000,1250,1600,20002500,3200,4000
Hope that helps a bit
06-24-2007, 07:34 PM   #21
Got it! I see...
Thanks Peter Zack!
camera, dslr, noob, photography, time
Noob flash questions related to K-x Muggins Flashes, Lighting, and Studio 3 12-14-2009 01:51 PM
couple noob questions LMRacing Troubleshooting and Beginner Help 4 06-20-2009 07:44 PM
Noob Duff Welcomes and Introductions 5 08-14-2008 04:14 PM
NooB with lens questions smitty Pentax SLR Lens Discussion 8 07-03-2007 12:15 PM
Noob learns lessons with K100D -- Part II: Lenses (with questions) bjsmith Pentax SLR Lens Discussion 16 06-18-2007 09:13 PM
All times are GMT -7. The time now is 09:20 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
