06-21-2007, 09:21 AM   #1
Staying RAW
How do I keep my K100D from reverting to Jpeg from RAW when I turn it off/back on?
Any way to keep it in auto-bracket?
Why doesn't my camera obey me?
(I've tried reading the manual but I suffer from male-related instruction and asking directions dysfunction.)
06-26-2007, 04:31 PM   #2
On the K10D it the option is under record mode change file format to RAW or RAW+, depending on which you want...
06-27-2007, 08:55 AM   #3
atnbirdie's Avatar
FYI, when I change from RAW to JPG using the Record mode menu on my K100D, the setting stays when I turn the camera off.
06-27-2007, 02:39 PM   #4
Press 'Menu'. You should already be in the 'Rec. Mode' section, scroll down to 'File Format', press '>' and select either RAW/RAW+ then press OK.
Happened to me too - the manual strongly suggested that you could use the external 'RAW' button to make permanent changes to what you shoot, but I found that it would revert back to its initial setting (jpg) whenever I turned the camera off then on, and even after I'd viewed some photos.
camera, dslr, photography
Did you convert to your religion, if not why are you staying? troglodyte General Talk 11 08-20-2010 09:36 AM
What's the easiest way to process RAW shots for a total RAW noob? Grimlock Digital Processing, Software, and Printing 6 09-03-2008 02:22 PM
Staying Pentax? Nikon D300? Where to go? rdrum76 Photographic Technique 0 10-14-2007 01:49 PM
Raw Therapee: free RAW converter/photo editor wheelgate Digital Processing, Software, and Printing 10 10-12-2007 06:44 PM
Staying RAW Bob Wallace Pentax DSLR Discussion 6 06-26-2007 09:37 AM
All times are GMT -7. The time now is 10:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
