01-12-2010, 02:37 AM   #46
JohnBee's Avatar
I woundn't know where to begin with a response tbh.
01-12-2010, 07:18 AM   #47
pcarfan's Avatar
QuoteOriginally posted by JohnBee Quote
PS. on the other hand, I was not able to the original images, do you have a link? Perhaps it's time to get my glasses changes
The original images were posted in another thread...
FULL res 6400 (So a very large file)
Flickr Photo Download: FULL RES (3 of 3)
FULL res 3200 (So a very large file)
Flickr Photo Download: FULL RES (2 of 3)
FULL res 1600 (large file)
Flickr Photo Download: FULL RES (1 of 3)
P.S: John, that image you posted was absolutely fabulous irrelevant to what iso was used.
01-12-2010, 07:23 AM   #48
pcarfan's Avatar
QuoteOriginally posted by Laurentiu Cristofor Quote
What I see in that area looks more like JPEG compression artifacts............If pcarfan's files are scaled down and compressed, what we might be seeing here are just side-effects of the algorithms used for scaling down and compressing the images. I've looked at his 3200 shot in original size and banding isn't half as obvious as it is in his OP.
I opened the same image in Rawtherapee ( to rule out LR causing it) and then exported to photoshop and saw the banding when viewed there and thus assumed it is neither the raw program nor the jpeg compression. So, I re-did the test now, but paid more careful attention to the image in rawtherapee before exporting and the banding is much less.
Here is the screen capture. I think there is less banding there, but there is still some.
The same image posted before (opened in LR and saved as Jpeg)
01-12-2010, 07:39 AM   #49
QuoteOriginally posted by pcarfan Quote
BTW, this is a picture-peeping problem not a pixel peeping one. You can see the horizontal pattern when you look at the entire picture. The horizontal discolorations become less distinct when you zoom in. If you can make a printout on a dye-sub printer, tell us if it looks better or worse.
01-12-2010, 07:48 AM   #50
pcarfan's Avatar
I checked with some other images, opened in RawTherapee , and the banding is there with the more recent images. So, I am fairly certain it's not the Raw converter nor the jpeg compression.
01-12-2010, 07:54 AM   #51
Yeah, I see the pattern in the camera preview even. For others, who haven't noticed this, all you have to do to replicate this is to crank ISO to the max and shoot a uniformly black surface (or any composition with a uniformly black surface).
01-12-2010, 08:49 AM   #52
Mr.Turnip's Avatar
QuoteOriginally posted by Igilligan Quote
Dang I really got to read this manual. You mean I can change metering between spot center matrix with the info / thumbwheel? I have been bangin back and forth thru the darn menu. A real pain...
YEP THERE IT IS
Thank you Claus >>> I really have to read the manual!!!
Hahaha what an idiot I am
Next time I am giving any advice or giving anyone any grief... Please link to this post!
LOOOL - no problem..glad you found out
I didn't read the manual either, I just pushed all the buttons I could ...but I'm glad I did discover it...it's a pretty neat feature
01-12-2010, 10:05 AM   #53
SergioFromSF's Avatar
Yes, great image! I too would love to learn to take and pp such an image quality.
01-12-2010, 01:19 PM   #54
pcarfan's Avatar
Yeah! JohnBee I hope you will come through with those steps. In my monitor, the faces of the two girls towards the left end seem to have a bit more 'burning' than the rest, but otherwise that image was absolutely awesome.
01-12-2010, 01:46 PM   #55
JohnBee's Avatar
Thanks everyone for your kind comments.
I'll look into putting together a walkthrough of the steps I used for that image.
01-13-2010, 02:12 AM   #56
Laurentiu Cristofor's Avatar
Having said that... the banding is well and accounted for in all three images at 100% as well as the resized ones.
It's obvious to me in the resized 6400 image. But I don't notice it in the other images - not as obvious as that 6400 or dpreview's images, anyway.
<image removed from quote to save space>
I can definitely see banding in the original image, although it's not obvious to me when looking at the original size. The new capture looks much better to me - if there's banding in it, it's below what I'd notice. I don't know what to say. I only use the Pentax software for conversion - I never used LR. I did use RawTherapee a few times to see if I can get better raw processing from it and what I noticed was that:
a) Pentax software was still better
b) when examining images at 100%, RawTherapee ones looked as if they were painted with a brush - I assume their algorithms are much more different than the Pentax ones.
QuoteOriginally posted by asdf Quote
Tried that and it doesn't work to me - not in preview, not at 100%. Could it just be a problem with some cameras, or could it be that it requires the sensor to be used a lot before this starts showing up, or could it be interference from some other electronic device?
01-13-2010, 02:21 AM   #57
Igilligan
Guest
Hey a quick question for those seeing the banding
Do you have battery grips on your cameras?
01-13-2010, 04:01 AM   #58
pcarfan's Avatar
No, I don't. I am fairly convinced it is the firmware update that also included the FineSharpness2 settings, and I need to find out how I can get back to the original firmware. Any ideas?
P.S: I went ahead and ordered the DA15 yesterday, couldn't resist the small packaging
01-13-2010, 10:20 AM   #59
Igilligan
Guest
Lucky you on the DA 15!!!!
I can't remember seeing any Retro firmware threads. Good luck with that search.
Are you getting the horz banding in all your ISO 3200> shots? I did not think it was that bad in the test shots you posted here. I guess it is like PF... once you see it you cant help but see it. I shot the Tammy 70-300 for a month before someone started talking about PF in one of my bird shots. After that... it was everywhere. If I did that to you on this K20/k7 banding, I am truly sorry. From my point of view it was never really an issue for me.
On my k20 I would see it worse in some scenes and not at all in others. There seemed to be no real consisistancy in what caused it. Sometimes it showed up in darker parts of the scenes, but even in lighter ones sometimes. And other times I did not really see it. I always assumed it had to do with the Jpg engine and sensor of the K20. Since I was not shooting raw, I blamed myself more than the camera.
01-13-2010, 11:22 AM   #60
Was your exposure such that the black surface appeared gray (i.e., it was not completely clipped)?
camera, choice, detail, dslr, iso, iso3200, iso6400, k-7, loss, noise, nr, photography, test
K-5 vs K-7 First ISO performance testing (ISO-6400) starscream Pentax News and Rumors 95 09-25-2010 07:02 PM
Pentax DA* 55mm 1.4 SDM (unscientific test) asdf Pentax SLR Lens Discussion 7 01-29-2010 02:20 PM
Unscientific Kx ISO testing Mr.Turnip Pentax DSLR Discussion 26 01-13-2010 02:31 PM
Very, Very unscientific, but of interest Ed in GA Pentax DSLR Discussion 41 06-21-2008 12:00 PM
The big unscientific RAW Converter Comparison HogRider Photographic Technique 0 02-21-2007 11:27 AM
All times are GMT -7. The time now is 12:13 AM. | See also: NikonForums.com, part of our network of photo forums!
