Originally posted by DanLoc78 i was just about to start a thread with almost the exact same title. are you still able to select autofocus points? i'm so confused...how would autofocus work without visible points? i think it would drive me insane.
Not sure if you're being facetious or not - I'd have thought you'd been around long enough to have seen an of the zillions of other long threads on this topic. But for the record, yes, you can still select focus points, using the LCD. So for the minority who depend on selecting focus points, it's still possible, just a bit more awkward, and if you're one of the few for whom that would make a difference, then that would be reason to spend more on a higher end camera. For the majority who either use center point only or who let the camera choose for them (and thus feedback on which was chosen doesn't help in the least, as there is no way to make use of that feedback), it's a non-issue.
