06-22-2007, 02:46 PM   #1
is K100D safe in glasshouses?
Hi guys,
last week me and my girlfriend went to Kew gardens, beautifull place... I think I will post some pics bit later
anyway, I was bit worried as we entered so called palm house. Since K100D doesn't have weather proof seals, is it safe to work in such humid conditions?? Or shall I avoid using it inside there or similar glasshouses
thx for advices
06-22-2007, 04:32 PM   #2
I am kind of new to photography but from what I have read/heard from other people is that you leave your camera in your camera bag when you go in the glasshouse for about 5~10 mins before you pull it out and use it. Same procedure when you are going out into the colder climate. I think this will help proventing condensation in the camera/lens.
However as I said, I am relatively new to photography so you better wait for other answers first!
Kenny
06-22-2007, 04:33 PM   #3
Arjay Bee's Avatar
Find the posts people have put up about going between extremes of temperature. When you go from a cool or cold climate into the humidity you will need to guard against condensation. Having the camera inside a plastic bag while it acclimatizes to the ambient glasshouse temp is the best way to go. When you leave the microclimate the problem is not present in the glass house situation. Leaving temperate environment and entering freezing you also have to be careful..
Kjao, Depends on how cold your base level temp is. For example I have my gear in my bag in a fairly chilly airconditioned room. If I take the camera out of the bag outside even up to ten minutes after leaving the room ithe temp inside the bag is still cold enough to cause the camera to fog all over but especially on the class and LCD surfaces. Gives a nice softfocus effect if I try to think positively about the situation but usually its a pain as I wait for the camera to literally warm up. btw I live in the tropics and it is a late wet season! Everything grows mildew if the airco isn't left on.
06-23-2007, 09:25 PM   #4
Arpe's Avatar
"is K100D safe in glasshouses?" - just make sure it doesn't throw any stones!!
bit, camera, dslr, k100d, photography
Safe ? Beachnutt Monthly Photo Contests 0 07-29-2010 10:18 AM
Are we as safe now graphicgr8s General Talk 139 01-08-2010 10:12 AM
Disassembling a K100D - safe, or stupid? R.ticle One Pentax DSLR Discussion 18 06-02-2009 05:50 PM
Are you sure thats safe??? Truax_photo Post Your Photos! 1 05-12-2008 10:30 AM
Safe vievetrick Post Your Photos! 5 10-22-2007 02:04 AM
All times are GMT -7. The time now is 07:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
