Originally posted by ktmkid111 Hi
I seem to have a problem using my TV mode on my K 100 super, I only got it recently.
When I set the shutter speed, and take a picture, the aperture does not change, and I though the aperture would set correctly to your chosen shutter speed, so anyway I only get black pictures, because the aperture is wrong.
Can you help?
You are getting black pictures because you are using TOO fast of a shutter speed. Whatever aperture is required for proper exposure (with your shutter speed and ISO) is no supported by your lens. Are you setting it to ISO100, 1/4000 indoors by any chance? When you go into Av mode with the lens wide open, what shutter speed are you getting?
With Tv, you run the risk of underexposed images if the aperture can not open up wide enough. With Av, you run the risk of blurred images if the shutter speed is too slow.
