Originally posted by Raybo Here's a quote from DP when they did the K20 review, i'm guessing it also has to apply to the K-7.
"Enabling D-Range doesn't appear to change the exposure yet is only available from ISO 200 upwards which suggests the sensor's native sensitivity may be ISO 200, hence offering slightly improved dynamic range at that setting."
DPR got that assumption wrong. The only reason the k-7 limits the iso to 200 with extended dynamic range, is with that option the image is actually taken with 1-stop less iso than what you set in the camera. So, if you choose iso1600 and take a shots with extended dynamic range, then the shot is actually taken at iso800. So, the minimum iso for this feature has to be 1-stop higher than the lowest iso possible, and has nothing to do with native iso. this was studied and explained by Gordon Good in DPR.
Hope this helps.
