11-25-2006, 07:02 AM   #16
Does it make a difference what focusing distance you're doing the test ? do you use the minimal, as close as you can be with your lens, or not ?
It appear I have a very slight front focus on mine.... I have to do a better test though..
11-25-2006, 08:15 AM   #17
jfdavis58's Avatar
Auto-focus testing
There's lots about this test that one should know before attempting it. Two items near the top of such a list: it's not an optical bench (with sub micrometer tools and fancy dedicated computers) that you will be using to perform the test, and your camera is a manufactured device-it's operating parameters are judged statistically to be in or out of spec when it was last inspected.
This test-either with the Jackson pdf and chart or via the book index page-is thought to work best at closest focus to the camera, wide open aperture. And herein lies another thing to know (posed as a question): will you regularly use the camera/lens in a similar fashion? With auto-focus-(FYI: I usually do my macro work with manual focus.)
11-28-2006, 01:41 PM   #18
Tony's Avatar
When i use the fa 50 1.4 with my K100D at very large apertures i always select the bottom right focus point to get a focus lock and then recompose the pic. It is the only way i can be sure i wont get a front focus issue. The focus points on my camera are not aligned right and if i use the spot focus i get front focus. I have got so used to this it does not bother me one bit and was thinking you may have misaligned focus points too that are only evident when using very large apertures that have narrow depth of field
11-28-2006, 05:50 PM   #19
This is a new one for me. I don't ordinarily do testing, unless I suspect I've got a problem, but out of curiosity, I decided to try Sam's test with K10. I had interesting results. I tested a FA35 f2.0, FA50 f1.4, FA77 lmt, and a FA135 f2.8. Just for kicks I added the FA28-105 f3.2-f4.5 @ 50mm to the Mix.
This of course is not the most accurate test, it is just to get a general idea. It seems I have a little front focusing, at minimum focus distance with both the 35 and the 50. It's not to bad though. If I backed off some, the situation improved. Both the 77 and the 135 were dead on. Oh, and I got the shock of my life when I pixel peeped at the 135, wide open. I always new this is a very good lens, but this thing is not just tack sharp, it's razor sharp. I'm going to have to use this lens more often.
My off the cuff conclusion is the body is fine, and I probably have had the same FF issues with the 35 and 50 on my DS all along, but never noticed, because I'm usually stopped down a stop or 2, and DOF is covering it.
Sam, I'm glad you were able to resolve your issues. You obviouly had one that was out of calibration. Now go out and have fun with it.
Cheers
-Alan
camera, dslr, front, photography
K-5 Manual Lens Front Focus & Focus Beep woes fixed kneonx Pentax K-5 & K-5 II 14 04-12-2014 03:47 PM
Front focus and back focus K-5 allantois Pentax K-5 & K-5 II 48 03-31-2012 09:21 PM
Front focus far away, back focus up close hjb981 Pentax K-5 & K-5 II 14 05-05-2011 01:28 AM
Trying to understand front focus/back focus thing 41ants Troubleshooting and Beginner Help 16 08-31-2010 08:42 AM
front focus, back focus or other? imfinetoday Pentax SLR Lens Discussion 23 07-08-2010 11:49 AM
All times are GMT -7. The time now is 06:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
