01-16-2010, 02:36 PM   #1
Front Focus and tungsten light question
Hi All,
I've done quite a bit of searching through the forums and I can see that it's very well documented that Pentax DSLRs (including my K20D) are prone to front focus under tungsten light.
I just wanted to ask, does the same thing happen under halogen lightning (posh tungsten I suppose)? The colour temperature is roughly the same in that the correct white balance would be to se it to tungsten, but I wanted to check with the forum community.
The reason I ask is that I've been calibrating my Sigma 100-300mm with the focus test chart from focustestchart.com and when at 300mm and focusing from about 2 metres away, it does indeed front focus under halogen lightning (not a huge amount, but deffo front focus). Setting the K20D autofocus adjust to -10 doesn't seem to correct it fully. As per the tungsten discussions I was fully expecting this to happen.
So - should I see the same with halogen lighting as others have seen with tungsten / yellow light ?
01-16-2010, 03:31 PM   #2
My k100d front focus too under tungsten light! But ok with other lighting!
My k 20d seem ok but I didnt test it fully under the tungsten light.
01-17-2010, 02:47 AM   #3
Noone else help me out here?
01-17-2010, 03:07 PM   #4
Marc Sabatella's Avatar
I don't knowthe answer, but would suggest you assume any strongly colored lighting - including halogen - is a poor choice for focus tests. Perform them in daylight for optimum results.
01-17-2010, 07:42 PM   #5
frank's Avatar
I've tested K10D/K20D/K-7 under tungsten light, the K10D/K20D indeed had front focusing problem under tungsten light, but seems Pentax has fixed this problem on K-7
If you wanna calibrate AF, better do it under the light condition where you want to use your lens. Or you can do it twice, one under daylight/window light, one under tungsten. Then just remember the AF adjustment value and adjust accordingly.
01-17-2010, 09:38 PM   #6
KungPOW's Avatar
I understood the front focus issue happened with anylight type that has higher amounts of infrared.
I know my K10D front focuses big time with the subject is lit with halogen work lights.
01-18-2010, 05:22 AM   #7
Thanks guys, I repeated the test under daylight and I'm still seeing a small amount of front-focus. I also did some googling on the Sigma 100-300mm f/4 and it seems to be quite prone to front focus, particularly at the longer lengths when focusing close to subjects.
I think I'm going to return it and get it calibrated by Sigma as the autofocus correction on the K20D doesn't seem to correct it enough.
01-18-2010, 12:10 PM   #8
QuoteOriginally posted by Big G Quote
Did you try the contrast auto-focus in live view? Perhaps, the phase detection AF and/or mirror need adjusting.
01-18-2010, 12:25 PM   #9
PentaxPoke's Avatar
I seem to remember Rice High (who is not too popular around here) went on and on about AF problems of Pentax cameras in tungsten light. I think that has been fixed on the K-7 though since it can measure color, if I am not mistaken.
camera, dslr, focus, front, front focus, halogen, k20d, light, lightning, photography, tungsten, tungsten light
POLL: Who has front-focusing in tungsten lighting? soccerjoe5 Pentax DSLR Discussion 17 02-01-2010 05:06 AM
Proposed solution to Tungsten Front Focus laissezfaire Pentax DSLR Discussion 6 01-20-2010 10:59 AM
Can K20 be adjusted for indoor Tungsten light? philbaum Pentax DSLR Discussion 12 07-22-2009 05:40 AM
EV low light focus question tarsus Photographic Technique 3 06-26-2008 08:22 AM
Tungsten light option k100d super problem? demoleman Pentax DSLR Discussion 17 02-18-2008 04:58 PM
All times are GMT -7. The time now is 05:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
