01-17-2010, 01:52 AM   #1
K10D Firmware Upgrade Question.
It's been a mighty good while since I have picked up my daughter's camera (K10D), but I am beginning to realize the value of its lightweight design (compared to my Nikon D300 & D3) for my just casual out-and-about shooting concerns. I am interested in upgrading to the current firmware available, and see that a 16MB card is suggested for this. My other DSLR's use CF cards, whilst the K10D (as you know) requires SD cards. The one in the K10D is of 4MB capacity - which is more than adequate for my shooting needs with it. I cannot see shelling out for a 16MB sized SD card, solely for the purpose of obtaining the firmware upgrade, and wondered if anyone had been successful with upgrading the firmware via a smaller capacity card.
Advanced thanks.
01-17-2010, 02:04 AM   #2
Vous pouvez sans problème faire la mise à jour du firmware avec une carte de 16Mo c'est ce que je fait, je garde cette carte mémoire pour faire la mise à jour, il faut que la carte mémoire ait une plus grande capacité que le firmware.
01-17-2010, 02:27 AM   #3
I assume you mean 4GB card (not MB) and yes 4GB will work.
01-17-2010, 02:36 AM   #4
axl
QuoteOriginally posted by Gimbal Quote
exactly what I thought.
And size of the SD doesn't matter. I have upgraded it with 512MBb...
01-17-2010, 02:58 AM   #5
Jasvox's Avatar
You have a 4Gb card....download the firmware onto it, load that into the camera, transfer from card onto camera, then remove, check firmware was loaded correctly, then re-load the card and format the card...it's a very easy process and no need for an extra card.
Jason
01-17-2010, 07:40 AM   #6
lavascript's Avatar
Yeah, you're confusing MEGAbytes and GIGAbytes. You do need a card that's at least 16 MEGAbytes, but you have a 4 GIGAbyte card, which is 256 times the capacity.
No worries.
01-17-2010, 04:09 PM   #7
Thanks everyone.
And, yes...I confused MB with GB (Whew...what a blunder ). As always, I appreciate the responses.
camera, capacity, card, cards, dslr, firmware, k10d, k10d firmware, photography, sd
K10D firmware update question ddula Pentax DSLR Discussion 7 08-15-2010 10:04 PM
Cannot upgrade firmware on K10D Jeanimal Pentax DSLR Discussion 11 07-03-2010 09:29 AM
K10d Firmware Question lats Pentax DSLR Discussion 8 11-30-2009 03:52 PM
K20D firmware upgrade question. ozzi-paul Pentax DSLR Discussion 4 12-11-2008 12:25 PM
K100D to K10D upgrade question DaddyO Pentax DSLR Discussion 6 03-04-2008 05:59 AM
All times are GMT -7. The time now is 05:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
