07-04-2007, 09:57 AM   #16
QuoteOriginally posted by axl Quote
I've been usig the DOF preview way of setting correct exposure time for my Hoya HMC 135, but after trying AE-L button after reading about it here, I think those days are gone.
Anyway both of them work, if you want to experiment, and fiddle around than you can use DOF way, if you don't have time just press the AE-L button...
I guess you could look at the two methods this way:
The DOF method, you set the shutter speed you want, then adjust the aperture. So it's kinda like Shutter priority.
The AE-L method, you set the aperture and let the camera select the shutter speed. So it's Aperture priority.
I have tried both and I find the AE-L method to be the easiest. You can see the shutter speed that is selected in the viewfinder after you hit the AE-L button, and can adjust the aperture if you need a different shutter speed.
Sam
08-15-2007, 11:03 AM   #17
Oldschool's Avatar
This topic has been very useful to me. My 50mm M 1.7 arrived today and I can't wait to play. I have one question; Do I have to press the AE-L button for every shot or only when I change the aperature? Thanks
08-16-2007, 09:09 AM   #18
QuoteOriginally posted by Oldschool Quote
That will depend on the lighting of the subject. If the lighting is constant, then you can take several pictures in a row. If the lighting changes (clouds moving in and out) then you should do the adjustment each time.
Also, you will have to press the AE-L button every time you shut the camera off.
Sam
aperture, av, camera, change, dslr, k100d, lenses, mode, photography
manual modes for flash fredok1 Pentax DSLR Discussion 1 05-17-2010 11:10 AM
Av settings on P or manual modes Papou Pentax SLR Lens Discussion 1 12-30-2008 05:50 PM
Manual Focus Lenses and K100D throndor Pentax SLR Lens Discussion 2 10-14-2008 02:27 PM
Picture Modes K100D richard64 Pentax DSLR Discussion 6 09-05-2007 03:59 AM
*ist DL Manual Lenses and M/Av Modes problem ossi Pentax DSLR Discussion 7 02-15-2007 09:43 PM
All times are GMT -7. The time now is 03:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
