Originally posted by dlacouture Problem is that it will work for wide open apertures only (as it won't stop the lens down anymore), so you would better use Av mode in this case anyway...
I guess there is no easy solution to this "mirror up" problem...
Perhaps I am mistaken with what you are saying. With the M42's in M mode and the lever switched to manual on the lens barrel, the aperture is 'stopped down' when you change the aperture setting on the aperture ring. The viewfinder gets darker. In my case, hitting the green button updates the shutter speed to any corresponding aperture change I make with the aperture ring. With the tape in place, I can adjust from 2.8 to 4 on the aperture ring, hit the green button and the shutter speed automatically doubles. This all occurs without any mirror flip if I use the tape. Otherwise, it sounds like I am taking a picture prior to taking the picture.
As mentioned, I don't have any M series lenses. I know in the case with these lenses, when you adjust the aperture ring, you can still view wide open. Then when hitting the green button, the camera stops the aperture down and meters and opens back up. The tape trick may not work in this case. But for the M42's that are bigger and as such cover the contacts, it seems to work.
I know that I can use the Av mode with the M42's but I had found the the metering seemed to be better and more consistent with my K10d if I used the M mode. I have not compared Av v. M mode with the Kx. Also, I enjoy using the M mode with my AF lens and I use it also with off camera flash. So it makes sense to me to learn one mode well.
