Originally posted by RBellavance Well, strictly speaking, the manual does not say what happens with the "Apply All" value when you select "Apply One", it only talks about the reverse. And I remember from my logics courses that A => B does not necessarily mean B => A...
Be practical, how would you tell if you set "Apply One" before or after "Apply All" after you did it? Both conditions would look the same as far as the interface goes. If it was the case that "Apply All" acted differently in the two cases, then wouldn't there have to be an indication in the interface to make it workable for the user so that they would know what was going on a month or two after they set it up? I personally wouldn't be able to remember what I did after three minutes.
If you could set "Apply One" and have the setting be applied to "Apply All", the first time you changed "Apply All", you would have to go back in and reapply all twenty "Apply One" settings as we know that setting "Apply All" means the "Apply All" setting is used when this happens. Sound practical? Something you want to do? Something anyone would want to do? Does it make sense for the Pentax engineers to design it like this?
I think the logic is more like C=A+B and therefore C=B+A, but I don't usually practice logic this early in the morning. :ugh:
Thank you
Russell
