01-25-2010, 02:51 AM   #1
milesy's Avatar
Dust on Focus Screen
HI All
not sure if this has been covered elsewhere to applogise if it has.
I have a K7 and have found that there is some dust / small hairs on the focus screen. Well i say on the focus screen because when i look through the viewfinder especially at bright light i can see these bits and peices (about 4 bits). If i remove the lens altogether i can still see them - so i figure its either on the mirror or the focus screen.
Nothing is showing up on the actualy images.
So using a fine lense brush i lightly brushed the focus screen - bits still there.
Lightly brush the mirro - bits still there.
Now im guessing my next move would be to removed the focus screen and clean behind it - but can anyone advise me if this is the best move or not??
Adrian
01-25-2010, 05:22 AM   #2
Egg Salad's Avatar
I can tell you by experience that it usually only gets worse.
I've got the same issue - the focus screen I have installed had a very adhesive foil on it.
When I removed it I got some fine particles on it (damn you, electricity!).
So I tried blowing it away - without success - ok, small on, the big one in the split center was gone but I had some more in it then.
Then I removed it completely and dipped it in alcohol and it's still not clean.
Now I've pretty much given up.
So if you don't have access to a cleanroom I wouldn't risk it.
01-25-2010, 05:33 AM   #3
try a blower... sometimes it will work, and you don't risk more particles onto the screen...
make sure you hold the body with the hole facing downwards... that way dust can fall out if it wants to.
01-25-2010, 06:42 AM   #4
Wheatfield's Avatar
Learn to live with it.
There is more potential to damage things than to get rid of the dust, and it will come back at some point anyway.
01-25-2010, 08:58 AM   #5
GeneV's Avatar
QuoteOriginally posted by Egg Salad Quote
That sounds like the Jinfinance screen. I just learned to live with it as well. I destroyed the first one that came trying to clean it. It is just not worth it.
01-25-2010, 09:00 AM   #6
Gooshin's Avatar
it adds character
01-25-2010, 11:47 AM   #7
Marc Sabatella's Avatar
I agree with the suggestions to leave it alone - it's at least as likely you'll make it worse or even ruin the screen than fix it, and it's guaranteed more will show up a few weeks later anyhow. Just get used to it. Dust works its way in, and eventually out again, in a never ending cycle.
01-26-2010, 08:14 AM   #8
Egg Salad's Avatar
Yes, it is the Split screen from Jinfinance.
Good screen but impossible to keep dust and hair-free.
If I get access to compressed air (not the canned air) I'll try to get everthing "clean" again.
01-26-2010, 08:15 AM   #9
navilink's Avatar
my k-x has a big dust (eraser-leftover like dust) on the viewfinder mirror itself.. the OPPOSITE side of the mirror (not facing inside)... tried to blow using blower, the dust won't go
01-26-2010, 10:12 AM   #10
i second the motions to leave it alone.
I had one piece of dust after changing my focusing screen from stock to a split screen from jnfinance.
when I used the blower, I got MANY more particles of dust.
I took it out, cleaned it several times with a blower and various other means and all that happened is that I got different dust particles distributed in different areas.
not worth it, chances are you'll just make it worse.
01-26-2010, 05:38 PM   #11
GeneV's Avatar
QuoteOriginally posted by steveeboy Quote
At least you didn't put a big scratchy mark in the matte area. That is what I did with the first one I bought. Thank goodness it was not a Katzeye.
bits, brush, camera, dslr, dust, focus, move, photography, screen
K-x focus screen drawing & Travor focus screen issue xjx Pentax DSLR and Camera Articles 2 06-06-2012 10:13 PM
Dust in focus screen tbirdas Pentax DSLR Discussion 2 09-06-2010 07:34 AM
How to clean some dots of dust inside the focus screen mpg Pentax Camera and Field Accessories 6 06-13-2009 01:28 PM
dust on my focusing screen? Javaslinger Troubleshooting and Beginner Help 2 03-17-2009 02:00 PM
Quick Question: Pentax KM screen replaceable with split-focus screen? vinzer Pentax Film SLR Discussion 2 01-06-2009 01:21 AM
All times are GMT -7. The time now is 04:50 PM. | See also: NikonForums.com, part of our network of photo forums!
