01-28-2010, 02:55 AM   #1
Why does my k20d flash twice when using trailing curtain sync?
Why does my k20d flash twice when using trailing curtain sync? The first flash doesn't seem to have any effect on the image but still, I wonder why it flashes at all. Do other brands do it the same way? I don't recall double flashing with my old 400d
01-28-2010, 03:07 AM   #2
Well, that's how P-TTL works...
A first flash is made before the actual pic to meter the scene, then the "real" flash occurs while the sensor is exposed.
It's also the case in standard, "first curtain" mode, but the two bursts are really near instantaneous...
01-28-2010, 03:25 AM   #3
sterretje's Avatar
Autofocus assist might be another cause (at least on my K10D). Never used rear curtain sync so not sure if it will behave different there.
01-28-2010, 03:56 AM   #4
QuoteOriginally posted by dlacouture Quote
Thank you very much for this answer. Is there a guide for P-TTL around here...the link about PTTL flashes takes me to a page with lots of external flashes. I'm more interrested in using the pop-up flash correctly
01-28-2010, 03:56 AM   #5
pcarfan's Avatar
This is the reason....
01-28-2010, 04:03 AM   #6
Well, unfortunately, the K10 and K20 P-TTL flash handling is really unpredictable, due to a strong sensitivity to reflection : as soon as you have a moderately reflective object in the scene, it will underexpose heavily...
You'd be better off with an off-board auto flash, or a manual one (not so difficult to handle once you went to Strobist.com and read the myriad of flash-related articles)...
01-28-2010, 05:37 AM   #7
Thanx for the tip...I'll head there
camera, curtain, dslr, flash, k20d, photography
Trailing curtain sync problem? hoanpham Troubleshooting and Beginner Help 3 11-20-2009 05:18 PM
trailing curtain sync with manual flash + k20d kristoffon Flashes, Lighting, and Studio 4 11-20-2009 04:35 PM
Other flash units for trailing curtain sync photos Garlic Capital Newby Troubleshooting and Beginner Help 5 06-08-2009 06:13 PM
Sunpak 383 trailing curtain sync bentax Pentax Camera and Field Accessories 5 08-31-2008 11:29 PM
Does my K200D have rear/trailing curtain flash sync? K200D Pentax DSLR Discussion 2 07-29-2008 06:32 PM
All times are GMT -7. The time now is 04:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
