Originally posted by aleonx3 Sorry, Gary, I could be wrong - since when he inserted the SD card the LED on the card slot blinks, it may be able to read off from the SD card. I could be totally off base.. sorry, just thought it may be worth a try.
Still could be worth holding the menu button while turning the camera on. At least you could see if anything happens beyond the battery indicator. I wouldn't try to load a firmware though unless the camera IS working. Could finalize the journey to brick status. Also check (may be a long shot) that there are no stuck buttons, the mode dial isn't stuck between 2 settings, things like that. Plug a USB into the camera and see if it'll talk to a computer. Without a card, the camera should start. With one, of course it should start as well but it seems plausible that if the card is bad, the camera will not start with the card in the slot. All worth a try and costs nothing to do...
