02-06-2010, 01:53 AM   #1
vertical band on images K20d
Hi, I've just purchased a K20d and the images are producing a vertical band on the left hand side in landscape and a horizontal line at the bottom of the image in portrait. This is happening in all image formats as well as at various exposures. Any idea’s what might be causing this? Cheers
PENTAX K20D  Photo
02-06-2010, 03:36 AM   #2
Urmas R.'s Avatar
As you just bought it, then you could replace it in the shop and not worry about it. Looks like a sensor issue.
02-06-2010, 04:18 AM   #3
bought it second hand unfortunately
02-06-2010, 05:06 AM   #4
Wheatfield's Avatar
I don't know about the camera, but fix that fan before someone gets hurt.
02-06-2010, 05:51 AM   #5
thanks for your maternal concern
02-06-2010, 09:24 AM   #6
What kind of light are you shooting in? Fluorescent lighting can cause banding in images over 1/60th of a second in shutter speed. The reason for this is that the kind of light isn't constant, it is actually a series of small pulses so only part of the sensor catches the light at one time.
02-06-2010, 11:35 AM   #7
are you severely underexposing the image? I've seen this banding when I take a picture that's been 4-5 stops underexposed (set to for studio lighting and I nudge the shutter speed over 1/180 so the strobes don't fire and I get a black frame)...
02-06-2010, 01:29 PM   #8
JayBee's Avatar
Vertical banding - K20d
That same issue was discussed here: https://www.pentaxforums.com/forums/pentax-dslr-discussion/71190-pentax-k20d-...-problems.html but with no real conclusion. I noticed it on a few shots with my K20D back in August, but nothing since. Perhaps to do with D-Range on? I normally don't use D-Range, but it was on for those shots where I noticed exactly the same banding as you show here.
02-06-2010, 09:27 PM   #9
Appreciate the replies.
I'm shooting in all types of lighting conditions, and trying various exposures. Also tried various ISO's and D Range. What I’m finding is, the more the image is over exposed the less you see the band/strip. Slight over exposure will almost remove the band totally, however, zooming in to 100% and beyond will reveal the band as a faint line. Shooting in hi contrast conditions always seems to result in a slightly darker band on the edge no matter what exposure I dial in.
02-06-2010, 09:56 PM   #10
Mallee Boy's Avatar
Its a sensor problem, had to send mine back to Pentax to get fixed.....fortuneatley under warranty.
02-06-2010, 10:52 PM   #11
romeovn
Guest
fix your fan first and then bring your camera to Pentax
02-07-2010, 12:16 AM   #12
If the sensor worked as well as the 12v fan I would be a very happy cool man.
03-17-2010, 03:15 PM   #13
Pentax Canada
I sent mine back to Pentax Canada to get fixed it. The service is wonderful. It took just a week to change the cmos sensor.
03-21-2010, 01:44 AM   #14
look at mine. https://www.pentaxforums.com/forums/pentax-dslr-discussion/93683-k20d-banding-issue.html
I only seen this in one photo and hope it want show up again. But you have a real problem when it shows up in every photo. Try to get your money back from the seller or you have to get it repaired or live with it.
03-21-2010, 11:33 AM   #15
ricoh.pentax's Avatar
its an occasional problem on my k200 too. try to turn off sr, bail the battery for 5 minutes then reinsert and turn it on again.. works on my on k200 .
band, camera, dslr, image, images, k20d, photography
Vertical bar on the right of photos taken with K20D vivi123 Pentax DSLR Discussion 17 08-01-2015 02:41 AM
K20D pic vertical line problem oceandeep Pentax DSLR Discussion 5 04-16-2010 10:24 AM
How to see images vertical images after download as vertical ? netuser Troubleshooting and Beginner Help 8 08-28-2009 03:48 PM
Thick Band on image (K20D) offertonhatter Pentax DSLR Discussion 7 07-14-2009 03:43 PM
K20D vertical strips phler2 Pentax DSLR Discussion 113 05-04-2009 12:59 PM
All times are GMT -7. The time now is 03:01 PM. | See also: NikonForums.com, part of our network of photo forums!
