02-07-2010, 06:28 PM   #1
Help with manual lenses on K-x
I just bought a K-x to use with my M42 manual lenses. I have the genuine Pentax adapter. There seems to be a problem with the focus confirmation hexagon. It doesn't show up at all. The only way I can focus isjust by eyeballing it.
Likewise, I turned on the focus trap feature and it doesn't freeze the shutter at all.
Also no in body stabilization with these lenses. It won't even let me turn it on.
My smc-m 200/4 lens doesnt work at all. The "F" flashes for the f stop info.
Thanks for any help!
02-07-2010, 06:43 PM   #2
Andi Lo's Avatar
I've tried my K-x with both M42s and M lenses and they work fine... so hopefully the following works
QuoteOriginally posted by stonedes Quote
Try
1. Enabling use of lenses with aperture ring
2. Use Av mode, with stop down metering (switch the lens to manual). Shutter Speed should change accordingly. You might have to dial + on the exposure compensation.
4. Half press the shutter while focusing, or you can assign AF / AE-L button to do AF (option2), and use that as focus assist. I'm not 100% sure whether there's hexagon or not, but it definitely beeped for me.
This is normal, M42s aren't supposed to have focus trap, it's only for K-mount lenses. If you REALLY need focus trap, short the 'A' pin by putting a aluminum foil between the lens and the mount.
Not sure what's wrong here. Shake Reduction should still be selectable even with no lens attached (in fact when you attach an M42 lens, the camera doesnt really care whether there's a lens attached or not). Maybe you've chosen 2 second timer (SR will automatically be disabled)?
This is normal, use Manual mode, and green button for metering after you set aperture on the lens
Hope that helps
02-08-2010, 09:37 AM   #3
Thanks Andi
Thank you for your help! I followed your advice and set the aperature ring in the custom menu. Made all the difference with the k mount lens.
Then it seems that I need to short the contacts on the mount when I mounted my m42's. I put a little foil on there and I got the same info as when I mounted the k mount lens.
02-08-2010, 10:31 AM   #4
Andi Lo's Avatar
It still boggles my mind why this option isn't just selected by default; it gives alot of people so much trouble! Personally I used to short my M42s for a while but decided that with the amount of lens changing that I do, it's not worth the hassle, so I just leave my camera at +2 compensation. Enjoy the lenses!
camera, dslr, focus, help, k-x, lenses, photography
Manual Metering on Pentax DSLRs with Manual and Automatic Lenses Adam Pentax DSLR and Camera Articles 20 01-06-2016 03:38 AM
Pentax Km and old manual lenses: SMC Takumars & Tamron Adaptall 2 lenses Kendrick Troubleshooting and Beginner Help 10 04-14-2010 03:23 AM
K7 and Manual Lenses IainG Pentax DSLR Discussion 9 02-13-2010 04:49 AM
using these manual lenses on my kx Deiberson Troubleshooting and Beginner Help 18 12-22-2009 01:15 PM
Manual lenses. eccs19 Pentax SLR Lens Discussion 6 08-16-2009 07:28 PM
All times are GMT -7. The time now is 10:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
