Originally posted by Steinback Supposedly the K-x even has a menu setting so you can use the green button like the depth of field preview button on the K10d to stop down manual lenses (if necessary) and turn on the light meter.
This won't work for M42 lenses, as they miss the aperture lever (they had a pin instead which can not be operated by DSLRs).
If your Takumar lens can be manually stopped down permanently ('M' setting on lens), just stop down on the lens and use Av mode on Camera.
If it's an 'A mode' aperture only lens it will work wide open only.
Please note that by M and A, I'm not talking about the lens series like K, M, A, FA, but about a switch on the lens itself.
