Originally posted by clipsed also probly lost some quality on the photos due to reduced size.
not to mention that half-empty bottle of Wild Turkey!
I haven't had any problems handheld. I've had problems on my very lightweight Slik Sprint Pro 3-Way tripod when the center post is extended. The mirror mass seems to be enough to cause an oscillation. So now when I put the camera on there I set the center as low as possible. I'll sometimes still get a tiny amount of shake on an HDR image, when the camera fires three in a row. That’s what happens when the tripod only weighs as much as the camera.
Otherwise, I haven’t experienced any blurry images at speeds where they shouldn’t occur. I personally have speculated that if there’s a problem it’s likely due to the use of NiMH cells. The K-x does seem to prefer powerful batteries. The sensor is held in place by magnetic fields, and if the field strength drops then the sensor will move. But, of course, that’s just a speculation.
