02-10-2010, 01:38 PM   #1
GordZ's Avatar
Folder/file name
Does any one know how to disable the Folder name ie: 101_0125 etc that is the date the file was created. My old *stDS just kept a running file number. I may only shoot 1/2doz pic today and a few days later a dozen or so and they are in different folders. Makes for a lot of unnecessary files especially on a month long trip. Each day has a different file you have to continually open up files to view the pic's. Date is already imbeded in the photo info. Any thoughts?
The K7 really rocks I am starting to master the exposure ISO etc. and get better
pics than my old *stDS.
02-11-2010, 02:07 AM   #2
For example, in k-x you can choose via setup how files will be named, simple names in folders with date or through files numbering.
02-11-2010, 06:10 AM   #3
GordZ's Avatar
I know you can change the file name but can you turn off the automatic file folder that the pic's are stored in. This automatically changes every day. All of these files with one or two pics becomes a big job moving pics in and out of folders when down loading to the computer. Any suggestions or do I just live with it?
02-11-2010, 07:33 AM   #4
Wheatfield's Avatar
This is explained on page 267 of your owners manual if you would care to do a little self help.
02-11-2010, 07:36 AM   #5
Lowell Goudge's Avatar
as weatfield said it is in the manual, but note, unless you delete all the folders on a card, the camera will always store your photos in the last one (i.e. the highest numbered folder)
also, even when turned off, every 500th shot in a folder will cause a new one to be created, each folder only holds 500 shots. that can't be turned off but is only an issue when shooting jpegs on big cards
02-11-2010, 01:44 PM   #6
GordZ's Avatar
Hi,
Thanks the defalt is the "Date" Folder that changes daily but I can select "PENTX" for a single folder. Got it
02-11-2010, 04:31 PM   #7
Wheatfield's Avatar
QuoteOriginally posted by GordZ Quote
Hi,
No worries. Now go read the rest of your manual.
02-11-2010, 06:12 PM   #8
Marc Sabatella's Avatar
If so, you're using the wrong software to download the images. Any decent program wouldn't bat an eye.
camera, date, dslr, file, files, name, photography
k-x: Issue with folder name?? yusuf Pentax DSLR Discussion 14 01-08-2011 10:46 AM
SD card folder partitions? FHPhotographer Pentax DSLR Discussion 3 01-18-2010 12:43 PM
Pentax File Folder Icons for Mac jmax Photographic Technique 2 08-16-2009 09:42 AM
Folder name?? Phaser Pentax DSLR Discussion 30 01-22-2009 05:56 AM
Folder organization/archiving joefru Pentax DSLR Discussion 47 05-04-2008 06:41 PM
All times are GMT -7. The time now is 01:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
