02-12-2010, 12:28 AM   #1
Time till picture preview slow (K-7)?
I searched but was unable to find something, so I apologize if this is gets asked often.
After taking a picture, it takes roughly a 1.5 - 2 seconds before a picture is show on the LCD of the K7. Is this working as intended? And if so, is there a way to speed this up? Currently using a class 6 16GB memory card.
02-12-2010, 01:20 AM   #2
Senior Moderator
Nass's Avatar
about the same for me - as intended I think
02-12-2010, 01:32 AM   #3
Turn off Lens Correction settings in Menu (Distortion and Chromatic Adjusment). That will speed up preview significantly. Lens corrections can be easely done later in software.
02-12-2010, 01:38 AM   #4
QuoteOriginally posted by Jadran Quote
Thanks this worked. Would you also know how to check the firmware version on the camera? :P
02-12-2010, 01:51 AM   #5
QuoteOriginally posted by drewx2 Quote
While powering the camera, keep the Menu button pressed. Or, you could try to download free software called PhotoMe, it will shows even more detailed info on firmware
02-12-2010, 03:46 AM   #6
hcc
hcc's Avatar
Drew,
This is normal and it is linked with the amount of post-processing that you set. The post-processing can take a few seconds, and the lens correction options are in particular slow.
However you do not need to wait to see the picture display to take another picture(s). You can take again a picture very quickly (within 0.5 to 1 s), without waiting for the LCD display. The delay may or may be enough for the SR to be ready, but if you take a picture with almost identical conditions to the previous one, you do not need to wait for the SR to stabilise again.
I have done several tries taking nearly 10 pictures in 10 seconds with the K-7, a Pentax DA18-250mm and Lens correction options ON. Each time I did not wait for the LCD dsplay and all the 10 pictures were good: practically I previewed at the later stage the pictures on the LCD.
Hope that it will help....
camera, dslr, photography, picture
Picture slow to show on LCD after K-7 firmware update jboyde Pentax DSLR Discussion 2 07-29-2010 12:58 PM
*istDL DOF Preview not working & Slow flash pop up. auspentax Pentax DSLR Discussion 3 07-07-2010 07:07 AM
K-x slow after picture is taken pakuchn Pentax DSLR Discussion 4 02-07-2010 01:06 PM
Super slow upload time Electric Eye Troubleshooting and Beginner Help 8 02-05-2009 04:08 PM
New K200D - Please help. Slow picture release sue Pentax DSLR Discussion 18 12-22-2008 09:36 PM
All times are GMT -7. The time now is 10:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
