02-12-2010, 04:48 AM   #1
Senior Moderator
Nass's Avatar
[k-7] AF adjustment for M42 lenses
Hello,
I have a few M42 lenses that I'd like to use on my K-7. I find it tricky to get accurate focus though so I have purchased a split screen which has helped greatly. However I would also like an accurate focus confirmation for these and I suspect that some of them are front/back focusing.
I note in the manual that the K-7 has to obtain an ID for a lens in order to save the setting. How does this work (if at all) with M42 - they do not pass an ID as far as I know? Or is the ID associated with the focal length for that lens? In other words if I mount a 135mm, and set it as 135mm, will the camera save the lens correction I set against the 135mm, so that when I next use it it will know to adjust the focus?
Thanks
02-12-2010, 04:52 AM   #2
I don't think that it's possible in any way to index adjusment for M42 lenses by ID. The only way is to use "Apply all" option for adjusment, wich is then applyed to any lens atached. This is a problem I am facing too, as I use few M42 lenses. Sadly, no way for camera to memorize adjusment for paritcular M42 lens.
02-12-2010, 07:23 AM   #3
Lowell Goudge's Avatar
what I would suggest is that you look at the AF accuracy or adjustment required for each lens, and determine a general adjustment factor that you would enter.
the K7 lets you select a factor to apply to all lenses, and then specific ones for unique lenses.
Therefore if you can adjust with a comon factor for all your lenses, and then only enter factors for lenses that don't meet this comon adjustment, you would have the best solution,
the M42 lenses, since they lack the communications pin (7th position from lens locking pin) they don;t have any ID and would get thegeneral correction factor.
02-12-2010, 07:44 AM   #4
Yes, that's the best approach. Thats what I did for my M42 lenses.
135mm, camera, dslr, focus, id, k-7, lens, lenses, m42, photography
adjustment of infinity focus on Kiron lenses Lowell Goudge Pentax SLR Lens Discussion 24 04-12-2010 05:19 PM
Manual lenses and focus adjustment max889 Pentax SLR Lens Discussion 3 09-07-2009 11:48 AM
infinity focus adjustment on M42 lenses Lowell Goudge Pentax SLR Lens Discussion 11 08-20-2009 01:49 PM
K20D and Custom AF Adjustment setting for individual lenses . . . Petermgr Pentax Film SLR Discussion 0 09-03-2008 07:46 PM
Does K20D's AF adjustment get applied to MF lenses? morfic Pentax DSLR Discussion 14 07-13-2008 11:09 AM
All times are GMT -7. The time now is 09:17 PM. | See also: NikonForums.com, part of our network of photo forums!
