02-13-2010, 08:54 PM   #1
SD card size for k100?
what is the largest size SD card i can use in my K100? i recently got a 16 gb card for a gift (but i have not opened it), and am afraid i will have to exchange it.
thanks,
02-13-2010, 08:57 PM   #2
PrimeObjectif's Avatar
Follow the instructions on this page and install this firmware upgrade for your K100D:
Software Downloads : Support & Service : PENTAX
If you do this, or if you've already installed the latest firmware, your 16GB card should work.
02-13-2010, 08:57 PM   #3
QuoteOriginally posted by coopsmommy Quote
thanks,
If you update the firmware you will be able to use high capacity sd cards. If you have not updated the firmware yet you will need a non high capacity sd card to do it.
02-13-2010, 09:15 PM   #4
thank you so much!
camera, card, dslr, photography, sd, sd card size, size
Memory Card Size Limit shideg Pentax Compact Cameras 7 04-12-2010 08:56 PM
sd card size greenhorne Pentax DSLR Discussion 24 04-11-2008 02:22 PM
Max size for an SD card in K10d russblack Pentax DSLR Discussion 1 03-11-2008 07:47 PM
Max size sd card for k100d/k10d ? shane Pentax DSLR Discussion 17 09-18-2007 01:12 AM
Maximum Memory Card Size ekim12987 Pentax DSLR Discussion 5 05-13-2007 10:51 PM
All times are GMT -7. The time now is 04:07 AM. | See also: NikonForums.com, part of our network of photo forums!
