Originally posted by imtheguy Yes, I have used it but have never used X mode. You have a non-standard flash setup?
Sorry, I don't remember any specific set of settings other than I just used it as I normally shoot. It must be in single-frame drive mode with no other menu settings that create additional frames (bracketing or multi-exposure). That much is in the book. It also must have focus when the time to shoot comes around. You can ensure that just by putting it into AF-C mode I THINK. I gotta go try that as soon as I send this.
I think you start simple and work up. Single frame, A priority, ensure focus or try AF-C,
You didn't say what lens so I would suggest swapping. If you are using an old K or M then try a DA or FA. I am going to go fire up my K20D and try a few thinkgs too.
I have a tamron 28-75mm f/2.8 on my k20d. For lighting, I have a cactus v4 set up with a lumopro lp120. Shouldn't be a problem to set off a flash with the interval shooting (i don't think).
From what I gathered, the manual says it automatically sets the drive mode to single frame when it enters interval mode. And I have tried manually settings it to single frame mode.
Focus is confirming with beeps and green hexagons.
The problem with A priority is I am lighting with a flash and do not want the shutter speed automatically set to balance with the ambient. Otherwise I would use it.
