07-06-2007, 04:23 AM   #16
QuoteOriginally posted by Deni Quote
Is there anything I can do to catch him with open eyes?
No, except you glue his eyes! ;-)
The pre-flash for P-TTL is always there. And K10D and K100D only support P-TTL flashes, especially for the built-in flash.
With external flash, depending on the flashgun's model, you can avoid the problem by putting the flash in Auto mode, i.e., to detect exposure with external sensor on the flash.
The best thing is to use TTL actually, which only *ist D/DS and DS2 support but that was history then.
For more read, see also:-
P-TTL Vs TTL
RiceHigh's Pentax Blog: Which Flash Units are Safe for Pentax DSLRs?
07-06-2007, 04:55 AM   #17
Ivan Glisin's Avatar
Use your Takumar 50/1.4 in "M" mode. In this case flash automatically switches to full power with no preflash. You can use the aperture to regulate exposure. You will find more details here (see section "Flash Reach Table for the DS"):
jr-worldwi.de: Photography: Technic
07-06-2007, 04:57 AM   #18
QuoteOriginally posted by RiceHigh Quote
Not always: there is a way around it. See my other post.
07-06-2007, 05:30 AM   #19
Case solved . When I use the 2s delay his eyes are wide open ! So if anyone else is having the same problem I suggest that.
I've found the super takumar and the built in flash are not really compatible. Even if the flash is set to ev -2 and I'm using f/16 tv=180 I get over exposed photo. Don't know why though. My takumar now is baking under the sun as I think it has a yellow tint and I hope the sun rays will take care of it. When I get home I'll do some more tests.
Though with the takumar and high iso I don't even need the flash , which is quite annoying, for the people in front and around it . Yeah and the focus aid is just as devastating as a machine gun would have been if used in Napoleonic wars .
07-06-2007, 05:38 AM   #20
QuoteOriginally posted by Ivan Glisin Quote
I actually personally discussed with Jens R before. The method does not always work, particularly I had tried with my DS and K100 and it won't work for all of my autofocus lenses. Furthermore, of course with digital lenses, we cannot even do the trick as there is no aperture ring.
buddy, camera, dslr, eyes, flash, photo, photography, results
Blurred images using flash (difficult problem) Eric Seavey Pentax DSLR Discussion 10 08-04-2010 12:29 AM
Using a manual flash for wedding portrait - too difficult? Josť Ramos Flashes, Lighting, and Studio 4 05-18-2010 12:15 PM
That flash hurts my eyes Grandpa crbrune Monthly Photo Contests 0 03-09-2009 12:55 PM
Kodak closes all Qualex film processing plants barondla Pentax Film SLR Discussion 4 01-05-2009 06:26 PM
Closed eyes when using the flash xfraser Flashes, Lighting, and Studio 5 01-31-2007 12:52 PM
All times are GMT -7. The time now is 08:03 AM. | See also: NikonForums.com, part of our network of photo forums!
