Originally posted by zxaar i was not aware that it could vary camera to camera.
Thanks for your posting , it might be helpful to others. on another forum i frequently visit, there was someone wondering about banding issue with canon 7d.
she did send her files to canon and canon refused to acknowledge problem. i will advice her to try to change her camera body, she might get rid of banding.
The pattern may vary, but I suspect the other poster is mistaken. There is no image to back up the claim. It's easy to reproduce the pattern (or show it's not there): just slightly overexpose a gray or black area at the highest ISO setting. To avoid this pattern noise, Sony's latest sensors have an A/D converter per column (or so I read).
EDIT:
"At the same time, however, the following problems occur in conventional CMOS sensors. Although the fixed pattern noise between pixels can be removed by the CDS circuits located at each column, a vertical form of fixed pattern noise oc- curs due to differences between the CDS circuits themselves.
Also a capacitor with a size larger than a certain value is required in the CDS circuit to record and hold the post-CDS signal, and this results in an increase in the area of this circuit. Furthermore, the recorded and stored analog signals are easily influenced by switching noise in the high-frequency band due to the horizon- tal transfer operations.
To resolve these problems, Sony adopted the column-parallel A/D conversion tech- nique. (See figure 2.) "
http://www.sony.net/Products/SC-HP/cx_news/vol47/pdf/featuring47.pdf
