02-17-2010, 03:48 PM   #1
K-x: Using flash as AF assist lamp (only)
Hi guys,
I' m still fresh owner of my K-x and as probably many other, I found up that AF is quite strugling in low light. User guide says, that in such a situation, I shall use flash as a AF assist lamp, since Pentax didn't bothered with dedicated one(shame, shame...)... And now it comes: is possible to use flash ONLY as an AF lamp, means that WILL fire while focusing, but WILL NOT while taking pictures? If not, is there any aftermarket product which will help, and won't break my spine and budget?
Thank's in advance!
02-17-2010, 03:49 PM   #2
Depends on the flash. The Metz 48/58 AF1 can be used that way.
02-17-2010, 03:55 PM   #3
but I probably won't find some program for build-in one, will I?
02-17-2010, 04:12 PM   #4
Believe me, you dont wanna use the integrated flash for af assist. Your subject is going to be really p*ssed off by the blinking strobe and its not all too effective.
02-17-2010, 11:33 PM   #5
sucks not to have a dedicated focus assist lamp huh?
here's a work around:
1. pop the flash up, half-shutter to subject for focus assist until focused properly
2. switch the focus to MANUAL
3. close the pop-up flash
4. make sure you and the subject don't move, then fire away!
02-18-2010, 12:13 AM   #6
Eruditass's Avatar
QuoteOriginally posted by RolloR Quote
Or you can put the pop-up flash in wireless mode and set the custom function to not contribute.
02-18-2010, 01:21 AM   #7
jayp's Avatar
QuoteOriginally posted by Eruditass Quote
Good advice! Can't find the custom function though, mind pointing it out? Thanks
02-18-2010, 06:14 AM   #8
Try: Menu=> Custom page 3 =>17. Flash in wireless mode => 2 Off....Seems like it do what I ask that to do...just can't realy see any improvement in low light
EDIT: It's RUBBISH...It still fires flash while capturing in low light
af, camera, dslr, flash, k-x, lamp, photography
AF assist lamp alwilliams Pentax DSLR Discussion 5 02-16-2010 08:21 AM
K7 focus assist lamp ? jpzk Pentax DSLR Discussion 10 12-30-2009 05:57 PM
K-7 AF assist lamp not turning on TheTenaciousOne Pentax DSLR Discussion 2 11-30-2009 07:12 PM
My little invention, focus assist lamp for any camera! Senseriffic Pentax Camera and Field Accessories 22 08-26-2009 05:06 AM
focus-assist lamp absence in k20d. Reportage Pentax DSLR Discussion 18 02-25-2009 07:47 PM
All times are GMT -7. The time now is 10:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
