This is straight from the pentaximaging.com site.
Manuals and Literature - Official PENTAX Imaging Web Site
If you just purchased the K-x you will need to upgrade the firmware. I did mine the night that I got it, about a week ago.
The orginal firmware version is 1.0 and the upgrade bumps you up to 1.01. Follow the directions exactly, you don't want to brick your K-x! Good luck.
Selected Model: K-x Black
Manuals Available for Download
Literature Available for Download
Software Available for Download
Search did not find any available documents.
Firmware Available for Download
PENTAX K-x FIRMWARE UPDATE VERSION 1.01 VERSION HISTORY
Version 1.01
- Added 3 effects to the Cross Processing presets 1, 2, and 3.
- Added Cross Processing function to the Green Mode.
- Improved battery level indicator accuracy and stability.
PREPARATION- You will need a blank, formatted memory card with a capacity of 32 MB or higher.
- You will need your camera's USB cable, or a memory card reader.
- Make sure your batteries are fully charged (or that you are using an optional AC adapter) to prevent power interruptions during the update process.
FIRMWARE UPDATE INSTRUCTIONS - WINDOWS- Click the Windows link below to download the self-extracting firmware archive file (kx_e101w.exe). Click SAVE to save the download file to your computer's hard drive. Saving it to your desktop, for example, will make it easy to find after the download is complete. Please note: this download file is not the firmware update file itself, but a compressed archive that must be expanded in the following step.
- Next, double click thedownload file to expand it. Once expanded, you will see a readme text file (README.TXT) and the firmware update file itself (FWDC206B.BIN). The readme file contains instructions similar to what you are reading on this page.
- You must now copy the firmware update file (FWDC206B.BIN) to your camera's memory card. When you connect the camera directly to your computer (or if you use a card reader), the memory card appears as a removable disk drive in the My Computer window. Make sure you are using a blank/formatted memory card, then drag & drop (or copy & paste) the firmware update file (FWDC206B.BIN) from the desktop to your removable disk window, which is the camera's memory card. Please note: You must put the firmware update file (FWDC206B.BIN) directly onto the removable disk; it cannot be in any sub-folders. It must be on the top (or root) level of the memory card.
- Now that you have copied the firmware update file (FWDC206B.BIN) to your camera's memory card, you are ready to install it. Make sure your camera is turned off and disconnected from the computer. Make sure that the memory card containing the firmware update file is inserted into your camera. Also, make sure you that you have adequate power in your camera with fully charged batteries.
- To begin the update, turn your camera on while holding down the MENU button. If you have followed the above instructions precisely, the camera will begin to load the new firmware. You will see the message "NOW LOADING" then the camera will display the firmware update menu.
- Select "YES" using your camera's 4-way controller (the default is "NO") then press your camera's OK button.
- The camera will now update its firmware. This may take a couple of minutes, so be careful to not interrupt the process.
- When the update is complete, you will see "COMPLETE" on your camera's LCD screen. Turn the camera off and remove the memory card.
- With the memory card removed from the camera, check your new firmware version by turning the camera back on while holding down the MENU button. Before you begin to take pictures again, be sure to format your memory card to erase the firmware update file.
FIRMWARE UPDATE INSTRUCTIONS - MACINTOSH
Mac users can follow this same process after clicking on the Macintosh download link below.
- Download and save the Macintosh download file.
- Decompress it with your Stuffit expander program if necessary (this step may be automatic).
- Connect the camera to the computer.
- Copy the firmware file (FWDC206B.BIN) to your camera's memory card, then disconnect the camera from the computer.
- Proceed with the installation of the firmware as outlined above.
Copyright December, 2009 Hoya Corporation. All rights reserved.
"PENTAX" and "K-x" are trademarks of Hoya Corporation.
Any other product and company names shown here are trademarks or registered trademarks of their respective companies. DOWNLOADS
