Originally posted by Snydly Thanks guys.
Ben, I can do the voltage check. Just to be clear though, the voltage will read at the terminals while the flash is on, or charged, right?
Old flashes have hudreds of volts at the terminals?
I'm thinking of a new 'practical joke' on my son's...
Thanks again...
Yes, the voltage will be present, when the flash is switched on. If you fire the flash, the votlage will drop to zero and when the flash then recycles it goes back to its trigger voltage value.
Some older flash guns can have a couple of hundred volts. I haver never had one of these flashes, but I have read reports by users who measured for instance certain Vivitar 283 modells at 600V! My own one is slghtly below 6 V, though and completely useable with a DSLR.
Ben
