02-19-2010, 11:47 AM   #1
MaKettle's Avatar
Need help with K10
My K10 is acting weird.
I have the camera set on center point focusing. In the past, as expected, I only ever saw the center dot illuminate in the view finder, up until last week that is. Now I see the center dot as well as the dot above and below (3 dots in a row straight up and down).
I've tried for week to figure this out, been through the the manual twice, up and down the camera menus more times then I can remember.
Is it operator error? most likely. Here is what happened between the times it was a single dot and the now triple dot display. By the way the camera still appears to be center focusing.
I was hurridly changing lenses during a timeout of my daughters basketball game, each lens has a diiferent focus bias that I use with the K10 in debug mode. One lens requires much more than the other, so much more that I need to go to the AF adjust menu twice to reach the offset. It never fails that when I try to do this quickly I always inadvertantly end up in the wrong menu, cancel and start over. I think this time I may have mistakenly enabled or disabled a "feature" while in one of those menu screens.
I've switched the lenses back, no luck (didn't think it was hardware problem anyway)
I played with SEL focus, works great, works just like the manual says it should.
Go back to center point focus, three dots. ?????
Can anyone help?
02-19-2010, 01:38 PM   #2
sterretje's Avatar
I can not really help, but did you try a reset (somewhere in the menus) to get all settings to factory standard?
camera, center, dot, dslr, focus, focusing, k10, lens, lenses, menu, photography, week
K10--k-7--k-5 mysterick Pentax DSLR Discussion 8 12-16-2010 07:34 PM
k10/flash help jmdeegan Troubleshooting and Beginner Help 3 10-28-2009 08:52 AM
K10 histogram 8540tomg Pentax DSLR Discussion 6 08-11-2008 09:19 PM
M and A lenses with k10 houstonmacgregor Pentax SLR Lens Discussion 2 07-25-2008 09:08 PM
K10 how to or what do I do now vievetrick Site Suggestions and Help 1 11-30-2006 05:12 PM
All times are GMT -7. The time now is 03:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
