02-20-2010, 01:10 PM   #1
K100D Light Meter Problems
It looks like the light meter on my trusty K100D has gone south after just about 5 years. I can use it in manual mode, but unless I inadvertently set something by mistake and have forgotten what I set, it looks like I have a manual aperture camera. AF is just fine...
My K20 is still going strong....
02-20-2010, 04:04 PM   #2
Marc Sabatella's Avatar
What specifically is happening or not happening? Do you mean in P mode, for instance, it won't set an appropriate exposure any more? It will just take pictures at some random aperture and shutter speed?
02-21-2010, 10:08 AM   #3
Well overall, I really do not know when it started. Scrolling back through some shots, that I just loaded, it looks about a week ago, and nothing happened to the camera. Didn't drop it, knock or bump it or anything. I was doing some work with the K20 and taking some shots with the K100 hand held and did not look at the results till just yesterday.
Overall, upon power-up and removing the lens cap, Tv tends to oscillate between 1/30 and 1/45 of a sec., so the meter is responding to light, just not at the right measurement. I can manually set Tv to 1/350 and it works just fine (M and Tv), otherwise Auto (Green), P and Av are kaupte (a very specific engineering test description term). Actually in P mode, it wants to pop the flash!
I reset the settings back to the original - no change. I just think that I have a manual camera now. I might just have to go get a light meter, or shoot a number of shots with varying shutter times till I get one that looks right...
PENTAX K100D  Photo
02-21-2010, 12:04 PM   #4
k0og's Avatar
Try this...
It MIGHT just be dirty contacts between the lens and the mount on the body. I had one of my Pentax-A lenses act up, and found some visible dirt on the contact surfaces. After wiping them clean with a clean handkerchief, all worked well. Maybe you are lucky, and that is all it is. Wipe both surfaces (the contacts on the back of the lens, and the contacts on the lens mount on the body).
-Joe-
QuoteOriginally posted by interested_observer Quote
02-21-2010, 02:59 PM   #5
Afternoon Joe,
Thanks for the suggestion. I gave it a try, and the range now expands to 1/125 sec, a bit better. It is isolated to the camera body as the problem is common across what ever lens I have mounted. I took a close look and did not see any dirt or anything else.
camera, dslr, k100d, light, meter, photography
K-x as a light meter Eagle_Friends Pentax DSLR Discussion 7 10-15-2010 05:32 AM
Help with light meter srpickel Troubleshooting and Beginner Help 6 02-18-2010 03:49 PM
Light Meter daacon Pentax Camera and Field Accessories 16 12-25-2009 10:09 PM
Using the K-m light meter - if it has one kitkat Troubleshooting and Beginner Help 14 07-11-2009 06:23 PM
Light meter calibration on K100D? Finn Pentax DSLR Discussion 3 03-07-2007 08:21 PM
All times are GMT -7. The time now is 06:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
