Actually this noise is also audible when you set long exposure time (and shoot), and when you simply raise mirror to clean sensor.
So apparently the noise is produced at any time that the mirror is raised and the sensor is exposed to light. so it's definitely not a SR.
I wonder what is this noise? is it a cooler or something?
Quote: Also have a dead pixel that is only showing up in live view mode not menu mode.
This might be a dust on the sensor. I had some as well, managed to blow off some of it. To remove it you need some thing that produces dust-less constant powerful air blow, need to direct it into the sensor with mirror raised and the stickied dust should go away... but this is dangerous procedure and ideally should only be performed in the service center.
By the way, this dust only shows on narrow apertures so perhaps you can live with it .. Problem is that every time a mirror is raised, some dust may pass to the sensor area, so it's hard to not have any dust at all if you ever change lenses.
