02-21-2010, 07:36 PM   #1
K-x AF/AE-L button operation in Manual focus mode
Hi everyone,
Just got my new K-x body, played with it for 1-2 days and it's wonderful. However, I've run into an mispleasing issue with my FA31. When MF is on, the focusing ring of FA31 is sooo sweet!.. And when you turn on AF, you have to "fight" with the in-body focusing motor everytime you need to correct the focusing.
However, there is a AF/AE-L button which can be assigned custom function #2: disable shutter button focus, focus only by pressing AF button. I thought, oh yeah, I found it! But it just doesn't work in MF mode. What made Pentax engineers not to do it also for MF: switch to AF programmatically, focus, switch back to MF in milliseconds? Ah, HOW convenient it would be!.. Dream of adding it to 1.02 firmware.
How do you fight this issue?
02-21-2010, 08:16 PM   #2
Eruditass's Avatar
hold the lens release button (which de-couples the AF motor with the lens) with my right hand and focus
All DA lenses have quick-shift focus which negates the need for this. Fighting the focus motor is bad.
02-21-2010, 08:46 PM   #3
QuoteOriginally posted by Eruditass Quote
Ah, thanks for the tip, Eruditass. It's not convenient, but it works. :)
02-22-2010, 04:09 AM   #4
pschlute's Avatar
Eruditass is correct, do NOT try to manually focus with a FA lens when in AF mode. Only the DA lenses have the "quick shift" clutch built into the lens. No firmware can change this.
Use the 31mm in manual focus mode.
02-22-2010, 05:12 AM   #5
Yes, pschlute, I understand, just think firmware engineers can electronically enable / disable AF for a couple of milliseconds needed to AF.
02-22-2010, 06:28 AM   #6
The focus motor connection is a mechanical one, as far as I know there is no way to withdraw the activator using electronic means. So a firmware update is not possible for this issue.
As previously said just press the lens release button to MF if you don't wish to switch to MF full time.
QuoteOriginally posted by Karellen Quote
02-22-2010, 07:32 AM   #7
Telfish, you mean AF/MF switch operates some mechanical clutch inside the body? Don't think so.
02-22-2010, 08:30 AM   #8
pbo
pbo's Avatar
I'm pretty sure he's right - after all, the AF connection between the body and lens is a screw - and it raises at the same time as you pull the switch on the side of the camera (I am not sure, but try looking at the lens mount as you're moving the AF/MF clutch - it sure looks like you're directly moving the screw in/out).
It's also spring-loaded - so it retracts when you're mounting a lens, but I don't think a camera can actually control the back-forth movement of it...
02-22-2010, 08:39 AM   #9
Wow, I checked it and it's really mechanical. Well then, holding lens release button seems ok for me. Thanks everyone for answers!
af, af/ae-l, button, camera, dslr, focus, issue, mf, mode, photography, switch
Kx EV +/- button in Manual Mode Rory Troubleshooting and Beginner Help 15 09-02-2010 09:25 PM
Any way to hack lenses to manual focus in AutoFocus mode (like the kit lens)? skyredoubt Pentax DSLR Discussion 8 08-07-2010 10:36 AM
K10D Manual Focus in AFS Mode? simon f Pentax DSLR Discussion 2 11-21-2007 10:58 PM
[K10D] {Manual Mode} Green Button with flash AVANT Pentax DSLR Discussion 6 07-13-2007 12:34 PM
K/M Lenses, Manual Mode and the Green Button Sailor Pentax DSLR Discussion 14 02-15-2007 10:48 AM
All times are GMT -7. The time now is 11:25 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
