Originally posted by patsyd If I am correct in reading your instructions, these 3 items will built something allowing me the opportunity to have my K-x automatically shoot this scenario (after pressing the control button on the IR once):
1 frame lasting 10 seconds at intervals of 30 seconds for a total of 45 minutes (or about 85 shots total).
Hi Patsy, glad you like the article. Yes, the timer remote looks identical to the one I have so it should have a 2.5mm plug and fit the 2.5mm socket from RS. But it is not the IR remote that starts it all off, you need to program the Timer Remote. When it is connected to the infrared remote it just closes the circuit for the button and causes an IR pulse each time. For your scenario, set the camera on manual or Tv to 10 seconds. Set the timer for a 1 second exposure and 30 second interval. (No need to set it to 10 seconds, the time for the exposure makes little difference as the IR only sends one pulse each time the circuit is activated and you setting it to 10 seconds on the camera will take care of it). Set the number of shots to 90 (2 shots per minute for 45 minutes). The button on the right under the screen is the one that starts the timer program running (I think, I am at work). As long as the infrared beam is picked up by the sensor on the front of the camera all should be fine and it will do what you want
