Originally posted by Docrwm As I said, I'm new to dSLR phtoography so please pardon what might be an obvious question but: Is the life of a dSLR SD card that much harder than the life of a SD card in other devices that they are more prone to break? I've never had an SD card that worked right initially then break unless physically damaged by external force.
Well mine have ended up in the washer and dryer for some unknown reason
Yeah, I mostly do my own laundry.
I wouldn't be surprised that a lot of the issues with SD cards has been with counterfeits, but not known to be counterfeit cards. Even legitimate stores have had issues with receiving counterfeits. With the prices having come down, and I'm sure margins being a lot less, the counterfeits probably aren't an issue any more. That said, I'm more wary of buying expensive cards than cards in the sweet spot because I figure there still might be enough profit in counterfeiting them. I can live without the best, fastest, cards for this little bit of caution. I usually buy new one card first, use it for a while to be sure, then buy more to just make sure I'm buying a somewhat know entity.
When, or if, I get a DSLR with video capabilities, I'll revise my actions, but probably, I will simply buy only a single known fast card, and just swap it in when I want need the speed. I just don't see the point of using expensive cards all the time, when probably 99% of the time I won't use the capability.
I am expecting at least one new DSLR body to have internal memory at this Photokina. The write and read speeds of SSD hard drives, even really slow ones, is so many times faster, it seems like at wow type of feature for someone to implement. 4Gb of SSD memory in a camera would do, I think, maybe 8Gb.
Thank you
Russell
